이 버전에는 잘못된 편집 사항이 있을 수 있습니다. 최신 확인된 스냅샷으로 전환하십시오.
필요한 것
이 단계는 번역되지 않았습니다. 번역을 도와주십시오
Carefully remove both wire harnesses connected to the pump.
Squeeze and pull back hose clamp.
Twist drain hose off of pump.
Using a 1/4" socket wrench, remove the three mounting screws.
Pull the pump out of place.
다른 14명이 해당 안내서를 완성하였습니다.
댓글 9개
i have a speed problem with my washer ...
please provide info on how to test the water pump once it's removed...
My clothes are still really wet.
Washer doesn't move doesn't do any thing it just hummus won't drain water
