주요 콘텐츠로 건너뛰기
기기를 수리하세요
수리할 권리
상점
소개
Learn how to find and remove the dustbin fiber collector from your Kenmore 78423.
  1. Grab the dustbin handle, press and hold the button at the top of the handle. Pull the dustbin up and away from the main body.
    • Grab the dustbin handle, press and hold the button at the top of the handle.
    • Pull the dustbin up and away from the main body.
  2. Press the button located beneath the circular opening on the dust bin; this will open the bottom of the dustbin. Properly dispose any contents of the dust bin into a wastebasket.
    • Press the button located beneath the circular opening on the dust bin; this will open the bottom of the dustbin.
    • Properly dispose any contents of the dust bin into a wastebasket.
  3. Grab the fiber collector using the finger holes on both sides of the base. The fiber collector is the black basket with the rounded base Turn the base a quarter-turn clockwise and pull it away from the dustbin
    • Grab the fiber collector using the finger holes on both sides of the base.
    • The fiber collector is the black basket with the rounded base
    • Turn the base a quarter-turn clockwise and pull it away from the dustbin
    • Remove the fiber and hair that may be stuck inside the fiber collector
결론
다른 2명이 해당 안내서를 완성하였습니다.
Christopher Bradley
회원 가입일: 2018년 09월 17일
681 평판
안내서 5개 작성하였습니다
CSU Fullerton, Team S2-G4, Bruce Fall 2018 CSU Fullerton, Team S2-G4, Bruce Fall 2018 회원
CSUF-BRUCE-F18S2G4
4 회원들
안내서 5개 작성하였습니다
thank you for your help. My sister in law didn’t have the manual, its typical of her husband. without the manual I probably would have broken the fiber collector. Appreciate your help.
joseph doyle - 답글
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 1
30일 전: 7
전체 시간: 197
