주요 콘텐츠로 건너뛰기
Kenmore 78423 Dustbin fiber collector Replacement
  1. Kenmore 78423 Dustbin fiber collector Replacement, Dust Bin: 1 단계, 이미지 1/2 Kenmore 78423 Dustbin fiber collector Replacement, Dust Bin: 1 단계, 이미지 2/2
    • Grab the dustbin handle, press and hold the button at the top of the handle.
    • Pull the dustbin up and away from the main body.
  2. Kenmore 78423 Dustbin fiber collector Replacement: 2 단계, 이미지 1/2 Kenmore 78423 Dustbin fiber collector Replacement: 2 단계, 이미지 2/2
    • Press the button located beneath the circular opening on the dust bin; this will open the bottom of the dustbin.
    • Properly dispose any contents of the dust bin into a wastebasket.
  3. Kenmore 78423 Dustbin fiber collector Replacement, Dustbin fiber collector: 3 단계, 이미지 1/3 Kenmore 78423 Dustbin fiber collector Replacement, Dustbin fiber collector: 3 단계, 이미지 2/3 Kenmore 78423 Dustbin fiber collector Replacement, Dustbin fiber collector: 3 단계, 이미지 3/3
    • Grab the fiber collector using the finger holes on both sides of the base.
    • The fiber collector is the black basket with the rounded base
    • Turn the base a quarter-turn clockwise and pull it away from the dustbin
    • Remove the fiber and hair that may be stuck inside the fiber collector
결론
다른 2명이 해당 안내서를 완성하였습니다.
Christopher Bradley
회원 가입일: 09/17/18
701 평판
안내서 5개 작성하였습니다
CSU Fullerton, Team S2-G4, Bruce Fall 2018 CSU Fullerton, Team S2-G4, Bruce Fall 2018 회원
CSUF-BRUCE-F18S2G4
4 회원들
안내서 10개 작성하였습니다
댓글 한 개
thank you for your help. My sister in law didn’t have the manual, its typical of her husband. without the manual I probably would have broken the fiber collector. Appreciate your help.
joseph doyle - 답글
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 1
30일 전: 4
전체 시간: 477
