이 버전에는 잘못된 편집 사항이 있을 수 있습니다. 최신 확인된 스냅샷으로 전환하십시오.
필요한 것
이 단계는 번역되지 않았습니다. 번역을 도와주십시오
Grab the dustbin handle, press and hold the button at the top of the handle.
Pull the dustbin up and away from the main body.
Press the button located beneath the circular opening on the dust bin; this will open the bottom of the dustbin.
Properly dispose any contents of the dust bin into a wastebasket.
Grab the fiber collector using the finger holes on both sides of the base.
Turn the base a quarter-turn clockwise and pull it away from the dustbin
Remove the fiber and hair that may be stuck inside the fiber collector
다른 2명이 해당 안내서를 완성하였습니다.
댓글 한 개
thank you for your help. My sister in law didn’t have the manual, its typical of her husband. without the manual I probably would have broken the fiber collector. Appreciate your help.
