소개
The headband adjustment piece inside the Kensington Hi-Fi Headphones 33137 allows the headband to be adjusted for better fit. This guide shows how to remove and replace this piece.
필요한 것
Starting with the left speaker first, pull out one side of the speaker clamp where the clamp enters the hole on the speaker cover.
After one side of the speaker clamp is removed from the speaker cover, pull the other side of the speaker clamp out.
Turn the headphones so that the inner tab of the speaker clamp where it attaches to the headband can be seen.
Pull the speaker clamp so that the metal lifts free of the headband.
Turn the headphones so that the metal pieces inside the headband covering can be seen.
