주요 콘텐츠로 건너뛰기
Kensington Hi-Fi Headphones 33137 Headband Inner Cover
필요한 것
  1. Kensington Hi-Fi Headphones 33137 Headband Inner Cover, Inner Headband Cover: 1 단계, 이미지 1/3 Kensington Hi-Fi Headphones 33137 Headband Inner Cover, Inner Headband Cover: 1 단계, 이미지 2/3 Kensington Hi-Fi Headphones 33137 Headband Inner Cover, Inner Headband Cover: 1 단계, 이미지 3/3
    • Starting with the left speaker first, pull out one side of the speaker clamp where the clamp enters the hole on the speaker cover.
    • Do not pull out the speaker clamp with too much force, or it may break.
    • After one side of the speaker clamp is removed from the speaker cover, pull the other side of the speaker clamp out.
  2. Kensington Hi-Fi Headphones 33137 Headband Inner Cover: 2 단계, 이미지 1/3 Kensington Hi-Fi Headphones 33137 Headband Inner Cover: 2 단계, 이미지 2/3 Kensington Hi-Fi Headphones 33137 Headband Inner Cover: 2 단계, 이미지 3/3
    • Repeat the process in Step 1 to remove the right speaker clamp.
  3. Kensington Hi-Fi Headphones 33137 Headband Inner Cover: 3 단계, 이미지 1/2 Kensington Hi-Fi Headphones 33137 Headband Inner Cover: 3 단계, 이미지 2/2
    • This picture shows the headphones with the speakers detached. Steps 1 and 2 are not necessary to replace the headband covers, however they do make the process easier.
    • Turn the headphones so that the inner headphone cover is visible.
  4. Kensington Hi-Fi Headphones 33137 Headband Inner Cover: 4 단계, 이미지 1/2 Kensington Hi-Fi Headphones 33137 Headband Inner Cover: 4 단계, 이미지 2/2
    • Use the Phillips #00 screwdriver to loosen and remove the screw holding the inner headphone cover in place.
    • The screw dimensions are as follows: Length to Head = 4 mm, Head Length = 1.5 mm, Head Diameter = 3.5 mm, Major Diameter = 2 mm, Pitch = 0.5 mm.
    • All steps can be followed on both the left or right side of the headphones to remove inner coverings.
  5. Kensington Hi-Fi Headphones 33137 Headband Inner Cover: 5 단계, 이미지 1/3 Kensington Hi-Fi Headphones 33137 Headband Inner Cover: 5 단계, 이미지 2/3 Kensington Hi-Fi Headphones 33137 Headband Inner Cover: 5 단계, 이미지 3/3
    • Use the screwdriver to pry the inner headband covering loose.
    • Do not push the inner covering panel too hard, or the plastic will break. Only apply enough pressure to lift the panel up slightly.
    • Once the inner covering is loose, pull it free from the headband with your fingers and set it aside.
    • Make sure to pull the inner cover free gently do avoid losing the adjustment piece within the cover. It falls out easily and can be lost.
결론
Alexis Carr
회원 가입일: 03/26/14
417 평판
안내서 4개 작성하였습니다
Clemson, Team 1-3, Benson Spring 2014 Clemson, Team 1-3, Benson Spring 2014 회원
CLEM-BENSON-S14S1G3
3 회원들
안내서 18개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 1
30일 전: 9
전체 시간: 439
