이 버전에는 잘못된 편집 사항이 있을 수 있습니다. 최신 확인된 스냅샷으로 전환하십시오.
필요한 것
이 단계는 번역되지 않았습니다. 번역을 도와주십시오
Starting with the left speaker first, pull out one side of the speaker clamp where the clamp enters the hole on the speaker cover.
After one side of the speaker clamp is removed from the speaker cover, pull the other side of the speaker clamp out.
Use the Phillips #00 screwdriver to loosen and remove the screw holding the inner headphone cover in place.
Use the screwdriver to pry the inner headband covering loose.
Once the inner covering is loose, pull it free from the headband with your fingers and set it aside.
Turn the headphones so that the inner tab of the speaker clamp where it attaches to the headband can be seen.
Pull the speaker clamp so that the metal lifts free of the headband.
