주요 콘텐츠로 건너뛰기
Kensington Hi-Fi Headphones 33137 Speaker Cover
  1. Kensington Hi-Fi Headphones 33137 Speaker Cover, Speaker Cover: 1 단계, 이미지 1/3 Kensington Hi-Fi Headphones 33137 Speaker Cover, Speaker Cover: 1 단계, 이미지 2/3 Kensington Hi-Fi Headphones 33137 Speaker Cover, Speaker Cover: 1 단계, 이미지 3/3
    • Starting with the left speaker first, pull out one side of the speaker clamp where the clamp enters the hole on the speaker cover.
    • Do not pull out the speaker clamp with too much force, or it may break.
    • After one side of the speaker clamp is removed from the speaker cover, pull the other side of the speaker clamp out.
  2. Kensington Hi-Fi Headphones 33137 Speaker Cover: 2 단계, 이미지 1/3 Kensington Hi-Fi Headphones 33137 Speaker Cover: 2 단계, 이미지 2/3 Kensington Hi-Fi Headphones 33137 Speaker Cover: 2 단계, 이미지 3/3
    • Repeat the process in Step 1 to remove the right speaker clamp.
  3. Kensington Hi-Fi Headphones 33137 Speaker Cover: 3 단계, 이미지 1/3 Kensington Hi-Fi Headphones 33137 Speaker Cover: 3 단계, 이미지 2/3 Kensington Hi-Fi Headphones 33137 Speaker Cover: 3 단계, 이미지 3/3
    • Hold the speaker cover in one hand and the speaker ear-padding in the other.
    • Turn the speaker cover counter-clockwise until it stops turning.
    • Pull the speaker cover and the speaker ear padding apart to expose the inner components of the speaker.
    • Make sure to pull the speakers apart gently to avoid disconnecting the speaker cable wires from the speaker.
    • If the speaker cover and ear-padding don't easily come apart, then make sure the speaker cover is fully turned.
    • Repeat this process for both speakers.
결론
William Sanders
회원 가입일: 03/26/14
573 평판
안내서 5개 작성하였습니다
Clemson, Team 1-3, Benson Spring 2014 Clemson, Team 1-3, Benson Spring 2014 회원
CLEM-BENSON-S14S1G3
3 회원들
안내서 18개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 0
30일 전: 0
전체 시간: 329
