주요 콘텐츠로 건너뛰기
Kenwood Chef A701A Power Cable Replacement
필요한 것
  1. Kenwood Chef A701A Power Cable Replacement, Remove Cable Grips: 1 단계, 이미지 1/2 Kenwood Chef A701A Power Cable Replacement, Remove Cable Grips: 1 단계, 이미지 2/2
    • Turn the mixer upside down
    • Remove the two screws holding the white cable grip.
    • Remove the black cable grip. The long screw also holds the cover onto the terminal block
  2. Kenwood Chef A701A Power Cable Replacement, Remove the old cable: 2 단계, 이미지 1/1
    • Remove the cable cover to expose the terminal block.
    • Remove the wires from the live and neutral terminals.
    • Thread the cables out though the cover and then from the mixer chassis
    • To refit simply follow the removal process in reverse
    • Be sure to connect the wires to the correct terminals, Brown - Live, Blue, Neutral.
    • If fitting a new plug ensure it is fitted with the appropriate fuse. If in any doubt consult a compitent electrician/electrical engineer
결론
다른 4명이 해당 안내서를 완성하였습니다.
Grant
회원 가입일: 09/29/15
143 평판
안내서 1개 작성함
댓글 한 개
Important addition: make sure you leave enough cable length free under the mixer for when you raise the top of the mixer during use to change accessories or remove the bowl. Our local electrical repair shop didn’t think to do this and as soon as I raised the top the cable was pulled out.
Karen Leach - 답글
댓글 쓰기
조회 통계:
24 시간 전: 2
7일 전: 15
30일 전: 97
전체 시간: 9,218
