주요 콘텐츠로 건너뛰기
Kenwood Chef: Replacement of planetary gear SER1018
보관된 가이드
해당 안내서는 단지 역사적인 목적으로 보관됩니다. 최신 버전 안내서를 사용하여 수리 하십시오.
필요한 것
  1. Kenwood Chef: Replacement of planetary gear SER1018, Remove the button from the locking lever: 1 단계, 이미지 1/1
    • Pull off the button
    • Remove the white rubber grommet
  2. Kenwood Chef: Replacement of planetary gear SER1018, Removal of the planetary gearbox: 2 단계, 이미지 1/2 Kenwood Chef: Replacement of planetary gear SER1018, Removal of the planetary gearbox: 2 단계, 이미지 2/2
    • Loosen the 6-point nut
    • Pull the planetary gear straight out
    • Loosen the Torx screws that hold the bottom of the case
  3. Kenwood Chef: Replacement of planetary gear SER1018, Bottom case: 3 단계, 이미지 1/2 Kenwood Chef: Replacement of planetary gear SER1018, Bottom case: 3 단계, 이미지 2/2
    • Remove the bottom case
    • The rubber gasket can be removed for cleaning
    • Remove felt mat
  4. Kenwood Chef: Replacement of planetary gear SER1018, High and medium speed drive: 4 단계, 이미지 1/2 Kenwood Chef: Replacement of planetary gear SER1018, High and medium speed drive: 4 단계, 이미지 2/2
    • Remove the Phillips screws to remove both plastic parts
    • The plastic parts are different
    • The screws are Imperial not Metric
  5. Kenwood Chef: Replacement of planetary gear SER1018, Top Housing Cover: 5 단계, 이미지 1/2 Kenwood Chef: Replacement of planetary gear SER1018, Top Housing Cover: 5 단계, 이미지 2/2
    • Remove the three torx screws
    • Lift off the housing cover
    • Pay attention to the white rubber buffer (red square)
  6. Kenwood Chef: Replacement of planetary gear SER1018, Challenge: Unscrew the hidden screw: 6 단계, 이미지 1/2 Kenwood Chef: Replacement of planetary gear SER1018, Challenge: Unscrew the hidden screw: 6 단계, 이미지 2/2
    • According to https://www.ifixit.com/User/1765524/jens, the plastic drive wheel can be unscrewed counterclockwise. To do this, the gearbox must be blocked. https://www.ifixit.com/User/730246/Julie... found a YouTube video documenting this. Starts at 7:25. Many thanks to Jens and Julien.
    • If the plastic drive wheel was removed in the above step, the next step can be skipped.
    • Loosening the Tx20 screw hidden by the plastic drive wheel is challenging
    • I was not able to pull off the plastic drive wheel
    • If you want to take a chance, you can drill a hole in the plastic drive wheel. However, I did not have the courage to do so.
    • I made myself a special tool -> see next step
  7. Kenwood Chef: Replacement of planetary gear SER1018, Special Tool: 7 단계, 이미지 1/3 Kenwood Chef: Replacement of planetary gear SER1018, Special Tool: 7 단계, 이미지 2/3 Kenwood Chef: Replacement of planetary gear SER1018, Special Tool: 7 단계, 이미지 3/3
    • I machined a 6mm open end wrench to be form fit with the Tx20 bit
    • A slot has been cut in the screw for easier re-assembly
  8. Kenwood Chef: Replacement of planetary gear SER1018, Open the gearbox housing: 8 단계, 이미지 1/2 Kenwood Chef: Replacement of planetary gear SER1018, Open the gearbox housing: 8 단계, 이미지 2/2
    • Remove guides (marked in red). They can be used after closing the case.
    • Remove seal. Has been replaced with silicone sealant.
  9. Kenwood Chef: Replacement of planetary gear SER1018, Planetary Gearbox: 9 단계, 이미지 1/3 Kenwood Chef: Replacement of planetary gear SER1018, Planetary Gearbox: 9 단계, 이미지 2/3 Kenwood Chef: Replacement of planetary gear SER1018, Planetary Gearbox: 9 단계, 이미지 3/3
    • The one with the cross drive is the old one
    • The new one has a bayonet lock. However, the whisks and kneading hooks are in the same position, opposite of the mixing bowl.
    • Difference in gear thickness doesn't seem to have an effect on the function.
  10. Kenwood Chef: Replacement of planetary gear SER1018, Drive Gear: 10 단계, 이미지 1/3 Kenwood Chef: Replacement of planetary gear SER1018, Drive Gear: 10 단계, 이미지 2/3 Kenwood Chef: Replacement of planetary gear SER1018, Drive Gear: 10 단계, 이미지 3/3
  11. Kenwood Chef: Replacement of planetary gear SER1018, Labels: 11 단계, 이미지 1/3 Kenwood Chef: Replacement of planetary gear SER1018, Labels: 11 단계, 이미지 2/3 Kenwood Chef: Replacement of planetary gear SER1018, Labels: 11 단계, 이미지 3/3
    • Cod. SER1018: Label from the plastic bag containing the three spare parts
    • Planetary gear label
    • 6-point nut: label and part
  12. Kenwood Chef: Replacement of planetary gear SER1018, Insert Gears: 12 단계, 이미지 1/3 Kenwood Chef: Replacement of planetary gear SER1018, Insert Gears: 12 단계, 이미지 2/3 Kenwood Chef: Replacement of planetary gear SER1018, Insert Gears: 12 단계, 이미지 3/3
    • Push each gear on its axis
    • Be careful with the spacers
  13. Kenwood Chef: Replacement of planetary gear SER1018, Assemble the gearbox housing: 13 단계, 이미지 1/2 Kenwood Chef: Replacement of planetary gear SER1018, Assemble the gearbox housing: 13 단계, 이미지 2/2
    • There is a lot of grease in the housing. Grease all the parts to be well lubricated.
    • Replace seal. See step 8.
    • Stand the machine upright on its feet and place the arm in the horizontal position. With the arm raised, the shaft falls out from the slow drive.
    • Gently push the parts together.
    • When disassembling, the screws were loose. That's why they were secured with a drop of screw lock.
    • Introduce the guides into the right places
  14. Kenwood Chef: Replacement of planetary gear SER1018, Insert Hidden Screw: 14 단계, 이미지 1/1
    • Insert hidden screw
    • Tighten with the special tool from step 7
결론
Continue from step 6 in reverse order to reassemble the device.
다른 3명이 해당 안내서를 완성하였습니다.
다음 번역가들에게 특별히 감사 드립니다:
de en
100%
oldturkey03님은 저희가 세상을 수리하는데 동참하신 분입니다! 기여하시겠습니까?
번역 시작하기 ›
Bruno M
회원 가입일: 02/14/15
872 평판
안내서 3개 작성하였습니다
댓글 10개
Hallo , sehr tolle Anleitung!! Meine Frage - nach dem Tausch des kompletten Getriebes (keine Einzelteile wie Zahnräder und dergleichen) wird das Getriebe nach ca. 10 -15 min. Knetarbeit sehr sehr heiß! Man kann sich eigentlich daran Verbrennungen zuziehen. Was kann da die Ursache sein??
Vielleicht hast du eine Idee dafür?
Lg Heinz
Heinz Stüttler - 답글
Hallo Heinz
Folgendes fällt mir zu der Frage ein:
- Das Getriebe sollte leichtgängig sein wenn man am Kunststoffzahnrad dreht. (Ohne Zahnriemen)
- Ist das eingesetzte Getriebe geschmiert? Roter Zapfen beim 5. Schritt
Gruss Bruno
Bruno M - 답글
Hallo Bruno,
das ist ja eine geniale Anleitung - KOMPLIMENT!
Bevor ich das Gerät zerlege, hätte ich eine Frage.
Zwischen Gummi und Planetengetriebe (siehe Bilder Step 1+2) fallen im Betrieb schwarze Krümel raus…
Was könnte das sein (hart gewordenes Getriebefett)?
Danke
Peter
Peter Tisch - 답글
Hallo Peter
Da kann ich Dir leider nicht wirklich helfen.
Ich vermute eher verschüttete Lebensmittel.
Gruss Bruno
Bruno M - 답글
Hallo Bruno,
vielen Dank für die detailierte Anleitung. Mir ist es gelunge das grosse Kunststoffzahnrad abzuschrauben, obwohl das verlinkte Video nicht funktioniert. Bei mir ist aber der untere Getriebedeckel gebrochen. Daher meine Frage: wo beziehst du deine Ersatzteile? Die meisten kommen aus UK oder Italien oder aus “zur Zeit nicht lieferbar”. Gibt es noch eine schlaue Quelle die Dr. Google unbekannt ist?
Danke
Armin
Armin Stampa - 답글
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 9
30일 전: 28
전체 시간: 11,463
