주요 콘텐츠로 건너뛰기
Kenwood DNX571HD Cooling Fan Replacement
필요한 것
  1. Kenwood DNX571HD Cooling Fan Replacement, CD/DVD Drive: 1 단계, 이미지 1/2 Kenwood DNX571HD Cooling Fan Replacement, CD/DVD Drive: 1 단계, 이미지 2/2
    • Unscrew the four 3.5mm side screws with a Phillips #1 screwdriver.
    • There are two screws per side.
  2. Kenwood DNX571HD Cooling Fan Replacement: 2 단계, 이미지 1/3 Kenwood DNX571HD Cooling Fan Replacement: 2 단계, 이미지 2/3 Kenwood DNX571HD Cooling Fan Replacement: 2 단계, 이미지 3/3
    • Use a spudger to unhook the plastic clips on the sides and top of the front panel. There are two clips on each side and one clip on the top.
    • Place the spudger between the plastic tab and the metal case and gently lift the spudger away from the case.
  3. Kenwood DNX571HD Cooling Fan Replacement: 3 단계, 이미지 1/1
    • Pull the top of the front panel out and down to remove front panel.
    • Remove the front panel gently so as not to damage the ribbon cables behind it.
  4. Kenwood DNX571HD Cooling Fan Replacement: 4 단계, 이미지 1/3 Kenwood DNX571HD Cooling Fan Replacement: 4 단계, 이미지 2/3 Kenwood DNX571HD Cooling Fan Replacement: 4 단계, 이미지 3/3
    • Unscrew the three 5mm screws from the top of the device using a Phillips #1 screwdriver.
    • Lift up to remove the top casing.
  5. Kenwood DNX571HD Cooling Fan Replacement: 5 단계, 이미지 1/1
    • Lift the CD drive carefully to expose the attached cable underneath.
  6. Kenwood DNX571HD Cooling Fan Replacement: 6 단계, 이미지 1/2 Kenwood DNX571HD Cooling Fan Replacement: 6 단계, 이미지 2/2
    • Flip up the black clasp with a spudger to disconnect the large white ribbon cable connecting the CD drive to the board underneath.
  7. Kenwood DNX571HD Cooling Fan Replacement, Cooling Fan: 7 단계, 이미지 1/1
    이 단계에 사용된 도구:
    구매
    • Carefully unplug the fan power cord with the tweezers.
  8. Kenwood DNX571HD Cooling Fan Replacement: 8 단계, 이미지 1/2 Kenwood DNX571HD Cooling Fan Replacement: 8 단계, 이미지 2/2
    • Unscrew the three 5mm length screws with the Phillips #1 screwdriver.
    • Remove the metal plate
    • Removing the plate will damage the heat sink compound. This will need to be replaced during reassembly.
  9. Kenwood DNX571HD Cooling Fan Replacement: 9 단계, 이미지 1/2 Kenwood DNX571HD Cooling Fan Replacement: 9 단계, 이미지 2/2
    • Unscrew the three 5.5mm long screws with a Phillips #1 screwdriver.
  10. Kenwood DNX571HD Cooling Fan Replacement: 10 단계, 이미지 1/3 Kenwood DNX571HD Cooling Fan Replacement: 10 단계, 이미지 2/3 Kenwood DNX571HD Cooling Fan Replacement: 10 단계, 이미지 3/3
    • Remove the four 5.5mm screws with the Phillips #1 screwdriver.
  11. Kenwood DNX571HD Cooling Fan Replacement: 11 단계, 이미지 1/1
    • Lift the top part of the unit up from the lower chassis.
  12. Kenwood DNX571HD Cooling Fan Replacement: 12 단계, 이미지 1/2 Kenwood DNX571HD Cooling Fan Replacement: 12 단계, 이미지 2/2
    • Remove the two 13mm long screws with a Phillips #1 screwdriver.
    • Gently thread the power cable through the circuit boards to separate the fan from the body of the stereo.
결론
Wendy Zaballos
회원 가입일: 09/17/18
952 평판
안내서 6개 작성하였습니다
Washington State, Team S1-G1, Hope Fall 2018 Washington State, Team S1-G1, Hope Fall 2018 회원
WSU-HOPE-F18S1G1
4 회원들
안내서 6개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 1
7일 전: 6
30일 전: 15
전체 시간: 943
