주요 콘텐츠로 건너뛰기
Kenwood DNX571HD LCD Touch Screen Replacement
필요한 것
  1. Kenwood DNX571HD LCD Touch Screen Replacement, LCD Touch Screen: 1 단계, 이미지 1/2 Kenwood DNX571HD LCD Touch Screen Replacement, LCD Touch Screen: 1 단계, 이미지 2/2
    • Turn off the stereo and remove from the vehicle before starting.
    • Unscrew the four 3.5mm side screws with a Phillips #1 screwdriver.
    • There are two screws per side.
  2. Kenwood DNX571HD LCD Touch Screen Replacement: 2 단계, 이미지 1/3 Kenwood DNX571HD LCD Touch Screen Replacement: 2 단계, 이미지 2/3 Kenwood DNX571HD LCD Touch Screen Replacement: 2 단계, 이미지 3/3
    • Use a spudger to unhook the plastic clips on the sides and top of the front panel. There are two clips on each side and one clip on the top.
    • Place the spudger between the plastic tab and the metal case and gently lift the spudger away from the case.
  3. Kenwood DNX571HD LCD Touch Screen Replacement: 3 단계, 이미지 1/1
    • Pull the top of the front panel out and down to remove front panel.
    • Remove the front panel gently so as not to damage the ribbon cables behind it.
  4. Kenwood DNX571HD LCD Touch Screen Replacement: 4 단계, 이미지 1/2 Kenwood DNX571HD LCD Touch Screen Replacement: 4 단계, 이미지 2/2
    • Flip up the black clasp with the spudger to disconnect the small white ribbon cable from the main board.
  5. Kenwood DNX571HD LCD Touch Screen Replacement: 5 단계, 이미지 1/2 Kenwood DNX571HD LCD Touch Screen Replacement: 5 단계, 이미지 2/2
    • Flip up the black clasp with the spudger to disconnect the large white ribbon cable from the main board.
  6. Kenwood DNX571HD LCD Touch Screen Replacement: 6 단계, 이미지 1/2 Kenwood DNX571HD LCD Touch Screen Replacement: 6 단계, 이미지 2/2
    • Flip up the black clasp with the spudger to disconnect the small white ribbon cable from the vertical board.
    • Carefully pull the ribbon from the clasp with the spudger.
  7. Kenwood DNX571HD LCD Touch Screen Replacement: 7 단계, 이미지 1/2 Kenwood DNX571HD LCD Touch Screen Replacement: 7 단계, 이미지 2/2
    • Flip up the black clasp with the spudger to disconnect the large orange ribbon cable from the main board.
  8. Kenwood DNX571HD LCD Touch Screen Replacement: 8 단계, 이미지 1/2 Kenwood DNX571HD LCD Touch Screen Replacement: 8 단계, 이미지 2/2
    • Push out the black clasp with the spudger to disconnect the small orange ribbon cable from the main board.
    • Gently push the ribbon out of the clasp with the spudger.
  9. Kenwood DNX571HD LCD Touch Screen Replacement: 9 단계, 이미지 1/2 Kenwood DNX571HD LCD Touch Screen Replacement: 9 단계, 이미지 2/2
    이 단계에 사용된 도구:
    구매
    • Using a pair of tweezers, gently pull up on the connector for the power cable to disconnect it from the main board.
  10. Kenwood DNX571HD LCD Touch Screen Replacement: 10 단계, 이미지 1/2 Kenwood DNX571HD LCD Touch Screen Replacement: 10 단계, 이미지 2/2
    • Unscrew the two 4mm screws holding down the board that is standing vertically with a Phillips #1 screwdriver.
    • Pull up on the board to remove it.
  11. Kenwood DNX571HD LCD Touch Screen Replacement: 11 단계, 이미지 1/2 Kenwood DNX571HD LCD Touch Screen Replacement: 11 단계, 이미지 2/2
    • Unscrew the four 5.5mm screws with a JIS #00 screwdriver.
    • Unscrew the 4mm screw with a Phillips #1 screwdriver.
    • Remove the disconnected circuit board.
  12. Kenwood DNX571HD LCD Touch Screen Replacement: 12 단계, 이미지 1/2 Kenwood DNX571HD LCD Touch Screen Replacement: 12 단계, 이미지 2/2
    • Unscrew the four 4mm screws on the main board with a Phillips #1 screwdriver.
    • Gently lift the board out of the casing.
    • Unscrew the 5.5mm screw on the metal plate with a JIS #00 screwdriver.
  13. Kenwood DNX571HD LCD Touch Screen Replacement: 13 단계, 이미지 1/1
    • Carefully remove the tape attaching the power cable to the metal plate.
  14. Kenwood DNX571HD LCD Touch Screen Replacement: 14 단계, 이미지 1/2 Kenwood DNX571HD LCD Touch Screen Replacement: 14 단계, 이미지 2/2
    • Use the spudger to unhook the metal tabs and detach the metal plate from the plastic housing.
    • Place the spudger between the metal tab and the plastic case and gently lift the spudger away from the case.
  15. Kenwood DNX571HD LCD Touch Screen Replacement: 15 단계, 이미지 1/2 Kenwood DNX571HD LCD Touch Screen Replacement: 15 단계, 이미지 2/2
    • Gently press the front of the screen to detach it from the plastic housing.
    • When removing the screen, gently flex out the plastic housing to help get the display past the plastic latch.
결론
다른 4명이 해당 안내서를 완성하였습니다.
Wendy Zaballos
회원 가입일: 09/17/18
952 평판
안내서 6개 작성하였습니다
Washington State, Team S1-G1, Hope Fall 2018 Washington State, Team S1-G1, Hope Fall 2018 회원
WSU-HOPE-F18S1G1
4 회원들
안내서 6개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 4
7일 전: 21
30일 전: 73
전체 시간: 9,444
