주요 콘텐츠로 건너뛰기
Kenwood DRV-N520 Dashcam Camera Replacement
필요한 것
  1. Kenwood DRV-N520 Dashcam Camera Replacement, Camera: 1 단계, 이미지 1/3 Kenwood DRV-N520 Dashcam Camera Replacement, Camera: 1 단계, 이미지 2/3 Kenwood DRV-N520 Dashcam Camera Replacement, Camera: 1 단계, 이미지 3/3
    • Remove the four 3mm screws from the back of the device using a Phillips #0 screwdriver.
    • Use a plastic opening tool to pry the back cover off of the device.
    • Remove four more 3mm screws from the copper plate immediately inside the device, also using a Phillips #0 screwdriver.
  2. Kenwood DRV-N520 Dashcam Camera Replacement: 2 단계, 이미지 1/3 Kenwood DRV-N520 Dashcam Camera Replacement: 2 단계, 이미지 2/3 Kenwood DRV-N520 Dashcam Camera Replacement: 2 단계, 이미지 3/3
    • Use a spudger to depress the metal locking tab while gently applying pulling pressure to the cable.
    • Remove the ribbon cable from the connector.
    • Then pull out the black and red wired cable from the connector.
  3. Kenwood DRV-N520 Dashcam Camera Replacement: 3 단계, 이미지 1/3 Kenwood DRV-N520 Dashcam Camera Replacement: 3 단계, 이미지 2/3 Kenwood DRV-N520 Dashcam Camera Replacement: 3 단계, 이미지 3/3
    • Remove the two screws from the corners of the wide end of the motherboard using a Phillips #0 screwdriver.
    • Lift the motherboard up and out of the device.
    • Remove the two 4mm Phillips #0 screws from the camera.
    • Lift the camera out from the device.
결론
By the end of this guide you will be able to know how to replace your camera dashcam. For any other questions ,please refer to the troubleshooting page.
Stephen
회원 가입일: 01/30/20
341 평판
안내서 2개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 4
30일 전: 14
전체 시간: 489
