주요 콘텐츠로 건너뛰기
Kenwood DRV-N520 Dashcam Motherboard Replacement
필요한 것
  1. Kenwood DRV-N520 Dashcam Motherboard Replacement, Motherboard: 1 단계, 이미지 1/1
    • Use a Phillips #0 screwdriver to remove the four 3mm screws in the device backing.
    • Remove the back cover.
  2. Kenwood DRV-N520 Dashcam Motherboard Replacement: 2 단계, 이미지 1/1
    • Remove the four 3mm screws in the copper plate using a Phillips #0 screwdriver.
    • Remove the copper plate to gain access to the motherboard.
  3. Kenwood DRV-N520 Dashcam Motherboard Replacement: 3 단계, 이미지 1/2 Kenwood DRV-N520 Dashcam Motherboard Replacement: 3 단계, 이미지 2/2
    • Remove the ribbon cable by gently pulling on it while using a spudger to apply pressure to the lever (orange arrow) holding it in place.
  4. Kenwood DRV-N520 Dashcam Motherboard Replacement: 4 단계, 이미지 1/3 Kenwood DRV-N520 Dashcam Motherboard Replacement: 4 단계, 이미지 2/3 Kenwood DRV-N520 Dashcam Motherboard Replacement: 4 단계, 이미지 3/3
    • Disconnect the speaker connection from the circuit board by using your fingers to apply pressure to the clip holding it in place.
    • Finally, remove the two screws from the two corners of the motherboard using a Phillips #0 screwdriver.
    • Remove the motherboard from the device.
결론
This will conclude the removal of the circuit card. Please refer to the troubleshooting guide for any question.
Stephen
회원 가입일: 01/30/20
341 평판
안내서 2개 작성하였습니다
댓글 한 개
I have a fault with the G FORCE sensor on my device. Any advise on how to deactivate or remove the sensor.
tomle3 - 답글
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 3
30일 전: 21
전체 시간: 203
