주요 콘텐츠로 건너뛰기
Kenwood DRV-N520 Dashcam Speaker Replacement
필요한 것
  1. Kenwood DRV-N520 Dashcam Speaker Replacement, Speaker: 1 단계, 이미지 1/3 Kenwood DRV-N520 Dashcam Speaker Replacement, Speaker: 1 단계, 이미지 2/3 Kenwood DRV-N520 Dashcam Speaker Replacement, Speaker: 1 단계, 이미지 3/3
    • Use a Phillips #0 screwdriver to remove the four 3mm screws from the device backing.
    • Remove the backing.
  2. Kenwood DRV-N520 Dashcam Speaker Replacement: 2 단계, 이미지 1/3 Kenwood DRV-N520 Dashcam Speaker Replacement: 2 단계, 이미지 2/3 Kenwood DRV-N520 Dashcam Speaker Replacement: 2 단계, 이미지 3/3
    • Use a Phillips #0 screwdriver to remove the four 3mm screws in the copper plate.
    • Remove the copper plate from the housing. The motherboard and capacitors should now be visible.
  3. Kenwood DRV-N520 Dashcam Speaker Replacement: 3 단계, 이미지 1/2 Kenwood DRV-N520 Dashcam Speaker Replacement: 3 단계, 이미지 2/2
    • Use the screwdriver to remove the two screws holding the motherboard in place.
    • Before attempting to remove the board, disconnect the camera by removing the ribbon cable from its corresponding connection on the board.
    • To remove the ribbon cable, use a plastic spudger to gently apply pressure to the lever that secures the cable in place while simultaneously applying a light pulling pressure on the ribbon cable.
    • Disconnect the speaker connections (red and black wires) from the motherboard by applying pressure to the clip on its corresponding socket.
    • Once all connections have been severed, gently remove the motherboard from the device casing.
    • The speaker unit and corresponding mounting hardware should now be visible.
  4. Kenwood DRV-N520 Dashcam Speaker Replacement: 4 단계, 이미지 1/2 Kenwood DRV-N520 Dashcam Speaker Replacement: 4 단계, 이미지 2/2
    • Use your Phillips #0 screwdriver to remove the two 3mm screws from the speaker's mounting bracket.
    • Remove the speaker from the device.
결론
To re-assemble your device, follow these steps in reverse order.
NathanGoodwin
회원 가입일: 01/30/20
136 평판
안내서 1개 작성함
ERAU-LAMOTHE-S20S14G1 ERAU-LAMOTHE-S20S14G1 회원
Local Repair Groups
4 회원들
안내서 3개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 2
30일 전: 14
전체 시간: 161
