주요 콘텐츠로 건너뛰기
Kenwood KDC-BT362U DVD-Drive Replacement
필요한 것
  1. Kenwood KDC-BT362U DVD-Drive Replacement, Front Panel: 1 단계, 이미지 1/1
    • Locate the face-plate eject button.
  2. Kenwood KDC-BT362U DVD-Drive Replacement: 2 단계, 이미지 1/2 Kenwood KDC-BT362U DVD-Drive Replacement: 2 단계, 이미지 2/2
    • Press the eject button with your forefinger.
    • Remove the face-plate.
  3. Kenwood KDC-BT362U DVD-Drive Replacement: 3 단계, 이미지 1/2 Kenwood KDC-BT362U DVD-Drive Replacement: 3 단계, 이미지 2/2
    • Starting on the top side, pop the front panel frame out.
    • Remove the face-plate frame.
  4. Kenwood KDC-BT362U DVD-Drive Replacement: 4 단계, 이미지 1/2 Kenwood KDC-BT362U DVD-Drive Replacement: 4 단계, 이미지 2/2
    • Use the plastic opening tool to pry open the tabs.
    • Repeat on the opposite side.
  5. Kenwood KDC-BT362U DVD-Drive Replacement: 5 단계, 이미지 1/1
    • Remove the front panel.
  6. Kenwood KDC-BT362U DVD-Drive Replacement, Metal Case: 6 단계, 이미지 1/3 Kenwood KDC-BT362U DVD-Drive Replacement, Metal Case: 6 단계, 이미지 2/3 Kenwood KDC-BT362U DVD-Drive Replacement, Metal Case: 6 단계, 이미지 3/3
    • Use the Phillips #0 Screwdriver to remove the screws off of the metal case.
  7. Kenwood KDC-BT362U DVD-Drive Replacement: 7 단계, 이미지 1/3 Kenwood KDC-BT362U DVD-Drive Replacement: 7 단계, 이미지 2/3 Kenwood KDC-BT362U DVD-Drive Replacement: 7 단계, 이미지 3/3
    • Carefully separate the top and bottom halves of the metal case apart.
    • Do not separate the metal case halves completely.
    • Carefully pull the DVD-Drive ribbon cable from the motherboard.
  8. Kenwood KDC-BT362U DVD-Drive Replacement, DVD-Drive: 8 단계, 이미지 1/2 Kenwood KDC-BT362U DVD-Drive Replacement, DVD-Drive: 8 단계, 이미지 2/2
    • Use the Phillips #0 Screwdriver to remove the three screws.
  9. Kenwood KDC-BT362U DVD-Drive Replacement: 9 단계, 이미지 1/1
    • Lift the DVD-Drive to separate it from the metal case.
결론
Steven Chov
회원 가입일: 10/04/16
349 평판
안내서 3개 작성하였습니다
USF Tampa, Team 2-5, Cagle Fall 2016 USF Tampa, Team 2-5, Cagle Fall 2016 회원
USFT-CAGLE-F16S2G5
4 회원들
안내서 5개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 2
30일 전: 8
전체 시간: 478
