주요 콘텐츠로 건너뛰기
Kenwood KDC-BT362U LCD Screen Replacement
필요한 것
  1. Kenwood KDC-BT362U LCD Screen Replacement, Front Panel: 1 단계, 이미지 1/1
    • Locate the face-plate eject button.
  2. Kenwood KDC-BT362U LCD Screen Replacement: 2 단계, 이미지 1/2 Kenwood KDC-BT362U LCD Screen Replacement: 2 단계, 이미지 2/2
    • Press the eject button with your forefinger.
    • Remove the face-plate.
  3. Kenwood KDC-BT362U LCD Screen Replacement: 3 단계, 이미지 1/2 Kenwood KDC-BT362U LCD Screen Replacement: 3 단계, 이미지 2/2
    • Starting on the top side, pop the front panel frame out.
    • Remove the face-plate frame.
  4. Kenwood KDC-BT362U LCD Screen Replacement: 4 단계, 이미지 1/2 Kenwood KDC-BT362U LCD Screen Replacement: 4 단계, 이미지 2/2
    • Use the plastic opening tool to pry open the tabs.
    • Repeat on the opposite side.
  5. Kenwood KDC-BT362U LCD Screen Replacement: 5 단계, 이미지 1/1
    • Remove the front panel.
  6. Kenwood KDC-BT362U LCD Screen Replacement, LCD Screen: 6 단계, 이미지 1/1
    • Use the Phillips #0 Screwdriver to remove the four screws.
  7. Kenwood KDC-BT362U LCD Screen Replacement: 7 단계, 이미지 1/2 Kenwood KDC-BT362U LCD Screen Replacement: 7 단계, 이미지 2/2
    • Use the plastic opening tool to pry it open.
  8. Kenwood KDC-BT362U LCD Screen Replacement: 8 단계, 이미지 1/2 Kenwood KDC-BT362U LCD Screen Replacement: 8 단계, 이미지 2/2
    • Lift and remove the motherboard to reveal the inside of the front panel.
  9. Kenwood KDC-BT362U LCD Screen Replacement: 9 단계, 이미지 1/2 Kenwood KDC-BT362U LCD Screen Replacement: 9 단계, 이미지 2/2
    • Use the metal spudger to straighten out the six pegs to allow the removal of the LCD Screen.
  10. Kenwood KDC-BT362U LCD Screen Replacement: 10 단계, 이미지 1/2 Kenwood KDC-BT362U LCD Screen Replacement: 10 단계, 이미지 2/2
    • Lift the LCD Screen to remove and replace it.
결론
Steven Chov
회원 가입일: 10/04/16
349 평판
안내서 3개 작성하였습니다
USF Tampa, Team 2-5, Cagle Fall 2016 USF Tampa, Team 2-5, Cagle Fall 2016 회원
USFT-CAGLE-F16S2G5
4 회원들
안내서 5개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 1
30일 전: 16
전체 시간: 735
