소개
A blown fuse can render the KDC-BT565U unusable. Replacing of a dead fuse with a proper 10 amp car fuse can restore the unit to working condition. This guide shows you how to replace this fuse.
NOTE: This requires the KDC-BT565U unit to be unmounted from the car. This may require specialist assistance.
필요한 것
To reassemble, follow these instructions in reverse order.
다른 4명이 해당 안내서를 완성하였습니다.
댓글 7개
I disconnect the negative side on my 502 DPX Kenwood in-dash stereo system I replace the alternator and hook everything back up and now I have no power to the receiver
same problem, how to remove the receiver
I accidentally touch power on the radio casing now the radio will not turn on and the fuse is good I need help it’s a kenwood KDC-7011
Did you ever find problem why your radio wouldn't turn on? Can you share with me. I have same problem
