주요 콘텐츠로 건너뛰기
Kenwood KDC-BT565U Fuse Replacement
필요한 것
  1. Kenwood KDC-BT565U Fuse Replacement, Fuse: 1 단계, 이미지 1/1
    • The fuse can be found on the back of your radio indicated by the red square in the photo.
  2. Kenwood KDC-BT565U Fuse Replacement: 2 단계, 이미지 1/2 Kenwood KDC-BT565U Fuse Replacement: 2 단계, 이미지 2/2
    • Pinch the fuse head with your fingers or a gripping tool to remove. This may require some force.
    • Reinsert a fuse that has the same amperage of the fuse that was previously removed (10 amps).
결론
To reassemble, follow these instructions in reverse order.
다른 4명이 해당 안내서를 완성하였습니다.
Darren Evans
회원 가입일: 02/15/17
273 평판
안내서 2개 작성하였습니다
USF Tampa, Team S2-G5, Lacy Spring 2017 USF Tampa, Team S2-G5, Lacy Spring 2017 회원
USFT-LACY-S17S2G5
4 회원들
안내서 11개 작성하였습니다
댓글 7개
I disconnect the negative side on my 502 DPX Kenwood in-dash stereo system I replace the alternator and hook everything back up and now I have no power to the receiver
jasonfisher036@gmail.com - 답글
it does not explain how to pull the reciever out.
d_lalande - 답글
same problem, how to remove the receiver
Jason Armondo - 답글
I accidentally touch power on the radio casing now the radio will not turn on and the fuse is good I need help it’s a kenwood KDC-7011
Javier Castellanos - 답글
Did you ever find problem why your radio wouldn't turn on? Can you share with me. I have same problem
Jannie watkins -
댓글 쓰기
조회 통계:
24 시간 전: 4
7일 전: 57
30일 전: 223
전체 시간: 21,535
