주요 콘텐츠로 건너뛰기
Kenwood KDC-BT565U LCD Screen Replacement
필요한 것
  1. Kenwood KDC-BT565U LCD Screen Replacement, Face Plate: 1 단계, 이미지 1/1
    • Press the eject button on the bottom left corner of the face plate.
  2. Kenwood KDC-BT565U LCD Screen Replacement: 2 단계, 이미지 1/3 Kenwood KDC-BT565U LCD Screen Replacement: 2 단계, 이미지 2/3 Kenwood KDC-BT565U LCD Screen Replacement: 2 단계, 이미지 3/3
    • Begin by slightly lifting the face plate out from the side located by the release button.
    • Slide towards the side of the eject button, then completely lift out.
  3. Kenwood KDC-BT565U LCD Screen Replacement, LCD Screen: 3 단계, 이미지 1/1
    • Remove the four 7.5mm Phillips #0 screws on the back of the face-plate.
  4. Kenwood KDC-BT565U LCD Screen Replacement: 4 단계, 이미지 1/2 Kenwood KDC-BT565U LCD Screen Replacement: 4 단계, 이미지 2/2
    • Use a spudger or prying tool to open the back of the face plate. Pry the back at multiple points around the edge of the face plate. This will take some patience. Applying too much force risks breaking the plastic.
  5. Kenwood KDC-BT565U LCD Screen Replacement: 5 단계, 이미지 1/2 Kenwood KDC-BT565U LCD Screen Replacement: 5 단계, 이미지 2/2
    • Lift and remove the motherboard to reveal the inside of the front panel.
    • You might need to pry the right side up with the spudger.
  6. Kenwood KDC-BT565U LCD Screen Replacement: 6 단계, 이미지 1/3 Kenwood KDC-BT565U LCD Screen Replacement: 6 단계, 이미지 2/3 Kenwood KDC-BT565U LCD Screen Replacement: 6 단계, 이미지 3/3
    • Use the plastic spudger to straighten out the six pegs to allow the removal of the LCD screen.
    • Make sure to use an ESD-safe prying tool when working on electrical boards. Here, we are using a plastic tool, not a metal one.
  7. Kenwood KDC-BT565U LCD Screen Replacement: 7 단계, 이미지 1/3 Kenwood KDC-BT565U LCD Screen Replacement: 7 단계, 이미지 2/3 Kenwood KDC-BT565U LCD Screen Replacement: 7 단계, 이미지 3/3
    • Lift the LCD screen to remove and replace it.
결론
다른 3명이 해당 안내서를 완성하였습니다.
Yusef Flowers
회원 가입일: 02/15/17
137 평판
안내서 1개 작성함
USF Tampa, Team S2-G5, Lacy Spring 2017 USF Tampa, Team S2-G5, Lacy Spring 2017 회원
USFT-LACY-S17S2G5
4 회원들
안내서 11개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 8
30일 전: 11
전체 시간: 468
