주요 콘텐츠로 건너뛰기
Keurig B60 Handle Replacement
필요한 것
  1. Keurig B60 Handle Replacement, Handle: 1 단계, 이미지 1/1
    • Lift the handle
  2. Keurig B60 Handle Replacement: 2 단계, 이미지 1/3 Keurig B60 Handle Replacement: 2 단계, 이미지 2/3 Keurig B60 Handle Replacement: 2 단계, 이미지 3/3
    • Locate and remove the two 9.5 mm Torx T15 screws on both sides of the handle.
  3. Keurig B60 Handle Replacement: 3 단계, 이미지 1/2 Keurig B60 Handle Replacement: 3 단계, 이미지 2/2
    • Remove the broken handle and replace with the new one
결론
다른 2명이 해당 안내서를 완성하였습니다.
Jake Wynn
회원 가입일: 04/11/16
830 평판
안내서 5개 작성하였습니다
Cal Poly, Team 1-7, Maness Spring 2016 Cal Poly, Team 1-7, Maness Spring 2016 회원
CPSU-MANESS-S16S1G7
5 회원들
안내서 5개 작성하였습니다
댓글 3개
The handle is locked up, partially ajar. Inserted a k-cup and handle locked when I was pulling it down
Meme Hill - 답글
Handle is locked in a partial open position. I raised handle, inserted-cup and when the handle
was pulled down it locked halfway down and does not move
Meme Hill - 답글
I also have a similar problem as Meme Hill, where the k cup area jostles and jams to an awkward position when moving the handle up (it cannot go up all the way), and it prevents full access to k cup, but I don't know why or what is preventing proper operation of handle swing. My current work around is keep on trying opening and closing, and eventually the handle can open all the way, and the k-cup area part swings out, but it really annoying. It should be accessible the first time when putting the handle up.
Lisa Munn - 답글
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 6
30일 전: 44
전체 시간: 2,735
