주요 콘텐츠로 건너뛰기
Keurig B60 Puncture Needle Replacement
필요한 것
  1. Keurig B60 Puncture Needle Replacement, Handle: 1 단계, 이미지 1/1
    • Lift the handle
  2. Keurig B60 Puncture Needle Replacement: 2 단계, 이미지 1/3 Keurig B60 Puncture Needle Replacement: 2 단계, 이미지 2/3 Keurig B60 Puncture Needle Replacement: 2 단계, 이미지 3/3
    • Locate and remove the two 9.5 mm Torx T15 screws on both sides of the handle.
  3. Keurig B60 Puncture Needle Replacement: 3 단계, 이미지 1/2 Keurig B60 Puncture Needle Replacement: 3 단계, 이미지 2/2
    • Remove the broken handle and replace with the new one
  4. Keurig B60 Puncture Needle Replacement, Puncture Needle: 4 단계, 이미지 1/1
    • Locate and remove the two 9.5 mm Phillips #1 screws.
    • Remove the plastic ring around the K-Cup Pack Holder
  5. Keurig B60 Puncture Needle Replacement: 5 단계, 이미지 1/1
    • Remove the two 9.5 mm Phillips #1 screws on the underside of the lid.
  6. Keurig B60 Puncture Needle Replacement: 6 단계, 이미지 1/2 Keurig B60 Puncture Needle Replacement: 6 단계, 이미지 2/2
    • Detach the lid from the Keurig.
  7. Keurig B60 Puncture Needle Replacement: 7 단계, 이미지 1/1
    • Locate and remove the two 9.5 mm Phillips #1 screws on the top of the puncture needle.
  8. Keurig B60 Puncture Needle Replacement: 8 단계, 이미지 1/3 Keurig B60 Puncture Needle Replacement: 8 단계, 이미지 2/3 Keurig B60 Puncture Needle Replacement: 8 단계, 이미지 3/3
    • Squeeze and pull on the hose to remove it from the Puncture Needle
    • Puncture needle should now be exposed
  9. Keurig B60 Puncture Needle Replacement: 9 단계, 이미지 1/3 Keurig B60 Puncture Needle Replacement: 9 단계, 이미지 2/3 Keurig B60 Puncture Needle Replacement: 9 단계, 이미지 3/3
    • Remove the Puncture Needle Assembly from Keurig
결론
다른 6명이 해당 안내서를 완성하였습니다.
Jake Wynn
회원 가입일: 04/11/16
830 평판
안내서 5개 작성하였습니다
Cal Poly, Team 1-7, Maness Spring 2016 Cal Poly, Team 1-7, Maness Spring 2016 회원
CPSU-MANESS-S16S1G7
5 회원들
안내서 5개 작성하였습니다
댓글 2개
Keurig B60 Puncture Needle Replacement. I need the punture needlees,upper and lower for this model.
johnneypa - 답글
I will be completing this guide but where do you get the replacement puncture needles for this model??
John Lawson
John Lawson - 답글
댓글 쓰기
조회 통계:
24 시간 전: 7
7일 전: 48
30일 전: 218
전체 시간: 29,858
