주요 콘텐츠로 건너뛰기
Keurig B70 Platinum Base Replacement
필요한 것
  1. Keurig B70 Platinum Base Replacement, Base: 1 단계, 이미지 1/2 Keurig B70 Platinum Base Replacement, Base: 1 단계, 이미지 2/2
    • Turn off and unplug the Keurig before starting.
    • Turn the Keurig upside down so the metal base is exposed.
    • Remove the five 12.0 mm screws.
  2. Keurig B70 Platinum Base Replacement: 2 단계, 이미지 1/2 Keurig B70 Platinum Base Replacement: 2 단계, 이미지 2/2
    • Lift the metal plate off the Keurig and hang it over the side of the device.
    • Be careful! The metal plate is sharp!
    • There are wires connected to the metal plate. Make sure the wires are not in the way of the internal components.
  3. Keurig B70 Platinum Base Replacement: 3 단계, 이미지 1/3 Keurig B70 Platinum Base Replacement: 3 단계, 이미지 2/3 Keurig B70 Platinum Base Replacement: 3 단계, 이미지 3/3
    • Remove the three 11.0 mm screws located on the upper left side of the base from within the tub-looking area.
    • Pull out the red and white wires and put it off to the side of the Keurig.
  4. Keurig B70 Platinum Base Replacement: 4 단계, 이미지 1/3 Keurig B70 Platinum Base Replacement: 4 단계, 이미지 2/3 Keurig B70 Platinum Base Replacement: 4 단계, 이미지 3/3
    • Pull out the water collector by gripping it tightly and lifting upwards.
  5. Keurig B70 Platinum Base Replacement: 5 단계, 이미지 1/3 Keurig B70 Platinum Base Replacement: 5 단계, 이미지 2/3 Keurig B70 Platinum Base Replacement: 5 단계, 이미지 3/3
    • Lift the tube, connected to the tank, off the black plastic hook and leave it off to the side of the hook.
  6. Keurig B70 Platinum Base Replacement: 6 단계, 이미지 1/3 Keurig B70 Platinum Base Replacement: 6 단계, 이미지 2/3 Keurig B70 Platinum Base Replacement: 6 단계, 이미지 3/3
    • Pull the power cord out from the plastic holder located near the water tank.
    • This step requires a bit of force so don't be afraid to pull harder!
  7. Keurig B70 Platinum Base Replacement: 7 단계, 이미지 1/2 Keurig B70 Platinum Base Replacement: 7 단계, 이미지 2/2
    • Remove the six 13.0 mm screws.
  8. Keurig B70 Platinum Base Replacement: 8 단계, 이미지 1/3 Keurig B70 Platinum Base Replacement: 8 단계, 이미지 2/3 Keurig B70 Platinum Base Replacement: 8 단계, 이미지 3/3
    • Lift the metal base and hover it over the opening of the black plastic base.
    • Carefully raise the plastic base over the metal base until it is removed.
    • Make sure to pull the power cord through the base as well!
결론
Steven Tran
회원 가입일: 10/14/18
329 평판
안내서 2개 작성하였습니다
UW Tacoma, Team S1-G6, Rose Fall 2018 UW Tacoma, Team S1-G6, Rose Fall 2018 회원
UWT-ROSE-F18S1G6
4 회원들
안내서 5개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 1
7일 전: 3
30일 전: 6
전체 시간: 549
