주요 콘텐츠로 건너뛰기
Keurig B70 Platinum K-Cup Portion Pack Holder Replacement
필요한 것
  1. Keurig B70 Platinum K-Cup Portion Pack Holder Replacement, K-Cup Portion Pack Holder: 1 단계, 이미지 1/2 Keurig B70 Platinum K-Cup Portion Pack Holder Replacement, K-Cup Portion Pack Holder: 1 단계, 이미지 2/2
    • Turn off and unplug the Keurig before starting.
    • Open the lid and remove the two 11.0 mm screws located below the K-Cup holder.
  2. Keurig B70 Platinum K-Cup Portion Pack Holder Replacement: 2 단계, 이미지 1/1
    • Pull the black plastic guard of the K-Cup housing away from the Keurig.
    • Depending on the angle, the guard can actually fall out instead. Be ready to catch it!
  3. Keurig B70 Platinum K-Cup Portion Pack Holder Replacement: 3 단계, 이미지 1/3 Keurig B70 Platinum K-Cup Portion Pack Holder Replacement: 3 단계, 이미지 2/3 Keurig B70 Platinum K-Cup Portion Pack Holder Replacement: 3 단계, 이미지 3/3
    • Push the black button at the bottom of the lid to remove the K-cup holder assembly.
    • From the top, lift the assembly out of the Keurig.
  4. Keurig B70 Platinum K-Cup Portion Pack Holder Replacement: 4 단계, 이미지 1/2 Keurig B70 Platinum K-Cup Portion Pack Holder Replacement: 4 단계, 이미지 2/2
    • Grab the top and the bottom of the holder assembly and pull it apart.
    • Be careful when pulling the assembly. There is a sharp needle!
    • This step requires a little force.
결론
Thu Hoang
회원 가입일: 10/17/18
217 평판
안내서 2개 작성하였습니다
UW Tacoma, Team S1-G6, Rose Fall 2018 UW Tacoma, Team S1-G6, Rose Fall 2018 회원
UWT-ROSE-F18S1G6
4 회원들
안내서 5개 작성하였습니다
댓글 한 개
Spring flew out as I was removing cup holder. Where does it go. How do I reinsert it?
slz2002 - 답글
댓글 쓰기
조회 통계:
24 시간 전: 1
7일 전: 7
30일 전: 20
전체 시간: 1,440
