주요 콘텐츠로 건너뛰기
Keurig B70 Platinum Water Filter Replacement
필요한 것
  1. Keurig B70 Platinum Water Filter Replacement, Water Filter: 1 단계, 이미지 1/3 Keurig B70 Platinum Water Filter Replacement, Water Filter: 1 단계, 이미지 2/3 Keurig B70 Platinum Water Filter Replacement, Water Filter: 1 단계, 이미지 3/3
    • Remove the water reservoir from the Keurig by lifting it upwards and pulling it outwards.
    • Be sure to empty the reservoir before continuing to the next step.
  2. Keurig B70 Platinum Water Filter Replacement: 2 단계, 이미지 1/3 Keurig B70 Platinum Water Filter Replacement: 2 단계, 이미지 2/3 Keurig B70 Platinum Water Filter Replacement: 2 단계, 이미지 3/3
    이 단계에 사용된 도구:
    구매
    • Remove the three 11.0 mm screws from the reservoir filter.
    • You may need to use tweezers to pull out the screws.
  3. Keurig B70 Platinum Water Filter Replacement: 3 단계, 이미지 1/3 Keurig B70 Platinum Water Filter Replacement: 3 단계, 이미지 2/3 Keurig B70 Platinum Water Filter Replacement: 3 단계, 이미지 3/3
    • Firmly twist the filter counterclockwise to remove it.
    • When adding the replacement filter, make sure the filter lines up with the screw holes.
결론
Emily Ramirez
회원 가입일: 10/14/18
97 평판
안내서 1개 작성함
UW Tacoma, Team S1-G6, Rose Fall 2018 UW Tacoma, Team S1-G6, Rose Fall 2018 회원
UWT-ROSE-F18S1G6
4 회원들
안내서 5개 작성하였습니다
댓글 4개
What are the two items inside the water resin?
There is the round item, and next to it an oblong item. I am really confused
Joan - 답글
The round item with 3 screws is the built in filter. The oblong item is the water level gauge.
Dacaria L -
I just ordered a filter starter kit. Do I just insert the kit on top of the round item?
Joan - 답글
I bought a Kuerig tall handle starter kit with charcoal filters. Tried install it over the existing built in filter, it didn’t fit. I think the round filter has to be removed in order to use the starter kit.
Dacaria L -
댓글 쓰기
조회 통계:
24 시간 전: 4
7일 전: 30
30일 전: 102
전체 시간: 10,725
