주요 콘텐츠로 건너뛰기
Keurig K10 MINI PLUS Cold Water Reserve Lid Replacement
필요한 것
  1. Keurig K10 MINI PLUS Cold Water Reserve Lid Replacement, Cold Water Reserve Lid: 1 단계, 이미지 1/2 Keurig K10 MINI PLUS Cold Water Reserve Lid Replacement, Cold Water Reserve Lid: 1 단계, 이미지 2/2
    • Lift the cold water reserve lid up to reveal its hinge.
    • Using either the metal spudger or the opening tool, gently pry the plastic out of the metal axle.
  2. Keurig K10 MINI PLUS Cold Water Reserve Lid Replacement: 2 단계, 이미지 1/1
    • Repeat the last step on the other hinge, making sure to keep a firm grasp on the lid as it comes off to avoid dropping it.
결론
Matt Bav
회원 가입일: 11/06/18
577 평판
안내서 4개 작성하였습니다
UMass Dartmouth, Team S5-G7, Gulbrandsen Fall 2018 UMass Dartmouth, Team S5-G7, Gulbrandsen Fall 2018 회원
UMASSD-GULBRANDSEN-F18S5G7
3 회원들
안내서 5개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 0
30일 전: 3
전체 시간: 423
