주요 콘텐츠로 건너뛰기
Keurig K10 MINI PLUS Top Needle Replacement
필요한 것
  1. Keurig K10 MINI PLUS Top Needle Replacement, Cup Holder: 1 단계, 이미지 1/3 Keurig K10 MINI PLUS Top Needle Replacement, Cup Holder: 1 단계, 이미지 2/3 Keurig K10 MINI PLUS Top Needle Replacement, Cup Holder: 1 단계, 이미지 3/3
    • Press on tab while pulling up on K-cup until you hear a click. Repeat for the remaining tabs. We found using the smallest of the "plastic opening tools" worked wonders.
  2. Keurig K10 MINI PLUS Top Needle Replacement: 2 단계, 이미지 1/2 Keurig K10 MINI PLUS Top Needle Replacement: 2 단계, 이미지 2/2
    • Once all of the tabs have been pressed, the K-Cup should just pop out. After, you just pull the remainder of the K-Cup. You have successfully removed the K-Cup.
  3. Keurig K10 MINI PLUS Top Needle Replacement, Top Needle: 3 단계, 이미지 1/2 Keurig K10 MINI PLUS Top Needle Replacement, Top Needle: 3 단계, 이미지 2/2
    • Remove two 9 mm Phillips #1 screws.
    • Avoid the top needle if at all possible. The needle may cut you and/or penetrate your skin.
    • The screws are located on the top of where the K-Cup would be.
  4. Keurig K10 MINI PLUS Top Needle Replacement: 4 단계, 이미지 1/3 Keurig K10 MINI PLUS Top Needle Replacement: 4 단계, 이미지 2/3 Keurig K10 MINI PLUS Top Needle Replacement: 4 단계, 이미지 3/3
    • Once you remove the screws, the top cover should come out.
    • You will then want to remove these screws which are the same size.
    • The needle is sharp, so be careful.
  5. Keurig K10 MINI PLUS Top Needle Replacement: 5 단계, 이미지 1/1
    • Once you get those removed, you are going to want to pull on the hose until it pops off.
    • Once the hose comes off, the needle will fall out by itself.
    • Be careful when picking up the needle as the needle is sharp.
결론
다른 2명이 해당 안내서를 완성하였습니다.
Mark Henein
회원 가입일: 02/04/16
369 평판
안내서 2개 작성하였습니다
USF Tampa, Team 17-6, Blackwell Winter 2016 USF Tampa, Team 17-6, Blackwell Winter 2016 회원
USFT-BLACKWELL-W16S17G6
2 회원들
안내서 2개 작성하였습니다
댓글 한 개
Where do you buy the needle I know you can get the exit needle with the holder, but can’t find this one.
tbushwacker - 답글
댓글 쓰기
조회 통계:
24 시간 전: 1
7일 전: 13
30일 전: 27
전체 시간: 4,949
