주요 콘텐츠로 건너뛰기
Keurig K10 Mini Plus Cup Holder Replacement
필요한 것
  1. Keurig K10 Mini Plus Cup Holder Replacement, Cup Holder: 1 단계, 이미지 1/3 Keurig K10 Mini Plus Cup Holder Replacement, Cup Holder: 1 단계, 이미지 2/3 Keurig K10 Mini Plus Cup Holder Replacement, Cup Holder: 1 단계, 이미지 3/3
    • Press on tab while pulling up on K-cup until you hear a click. Repeat for the remaining tabs. We found using the smallest of the "plastic opening tools" worked wonders.
  2. Keurig K10 Mini Plus Cup Holder Replacement: 2 단계, 이미지 1/2 Keurig K10 Mini Plus Cup Holder Replacement: 2 단계, 이미지 2/2
    • Once all of the tabs have been pressed, the K-Cup should just pop out. After, you just pull the remainder of the K-Cup. You have successfully removed the K-Cup.
결론
Mark Henein
회원 가입일: 02/04/16
369 평판
안내서 2개 작성하였습니다
USF Tampa, Team 17-6, Blackwell Winter 2016 USF Tampa, Team 17-6, Blackwell Winter 2016 회원
USFT-BLACKWELL-W16S17G6
2 회원들
안내서 2개 작성하였습니다
댓글 한 개
I accidentally removed the k cup holder while wiping it out. Now I have the holder plus 3 small plastic and 1 rubber circular pieces. How do I put it back together again? I have the same Kuerig mini as pictured here.
Marie - 답글
댓글 쓰기
조회 통계:
24 시간 전: 1
7일 전: 5
30일 전: 9
전체 시간: 1,433
