주요 콘텐츠로 건너뛰기
Keurig K40 Bottom Water Filter Replacement
필요한 것
  1. Keurig K40 Bottom Water Filter Replacement, Bottom Water Filter: 1 단계, 이미지 1/2 Keurig K40 Bottom Water Filter Replacement, Bottom Water Filter: 1 단계, 이미지 2/2
    • Flip the device on its side so that the metal faces you.
    • Begin by unscrewing the five 1.5mm bottom screws with a #0 phillips head screwdriver.
  2. Keurig K40 Bottom Water Filter Replacement: 2 단계, 이미지 1/2 Keurig K40 Bottom Water Filter Replacement: 2 단계, 이미지 2/2
    • Once the base is unscrewed, remove the base from the plastic wedges used to hold it in place.
    • The wires do not need to be cut as this repair will not harm or use them.
  3. Keurig K40 Bottom Water Filter Replacement: 3 단계, 이미지 1/2 Keurig K40 Bottom Water Filter Replacement: 3 단계, 이미지 2/2
    • Using a size 0 Philips head screwdriver, remove two 1.2mm screws that hold the filter in place.
    • Pull the pump back to remove it from the slot it was in.
  4. Keurig K40 Bottom Water Filter Replacement: 4 단계, 이미지 1/1
    • Grip where the filter and the flow line connect and pull apart until they are separated.
    • Clean or obtain a new filter and put back together. This is done by repeating the steps in reverse, putting the device back together.
    There is no ffilter on K-40 keurig maker
    keithpawpaw - 답글
    I thought so too but I followed the above directions and finally was able to pull straight up and free the filter. I can't see that it is dirty but ran water through both ends anyway. Still looked clean to me so I will just purchase a new one. Hang in. You can do it!
    kd4rvn - 답글
결론
다른 12명이 해당 안내서를 완성하였습니다.
jonathan
회원 가입일: 02/08/16
738 평판
안내서 2개 작성하였습니다
USF Tampa, Team 6-1, Eyestone Spring 2016 USF Tampa, Team 6-1, Eyestone Spring 2016 회원
USFT-EYESTONE-S16S6G1
3 회원들
안내서 5개 작성하였습니다
댓글 13개
Where do you obtain a new filter?
Anthony Montoya - 답글
I have the same question as Anthony. Every Keurig filter I see is the charcoal filter that takes 2 seconds to change
Matt Baum - 답글
[|i have the same question as well.. I don’t see anywhere selling a new filter…]
eddie mayfield - 답글
I need the filter, where do I buy a new Filter?
Gladys Karina Andino - 답글
The answer seems to be: “You don’t.”
Van Davis - 답글
Wow all this to replace filter? I cleaned the machine with filter in, will the filter be ok yet. What a hassle
kkohl27 - 답글
I added 2 O rings, one at the bottom of the water reservoir other in between the ripped hose and housing. It’s been 24hrs since repair and no leak
Sergio Polanco - 답글
First of all I think this is a bunch of bull on Keurigs part A customer has to get screwdrivers and $@$* and take the thing apart to get to the filter and then if you screw it up then what and now I see people are not even getting answers on how to get a new filter thanks Keurig I think you should freaking give everybody a new Keurig without charging them
Sandra Cuthbert - 답글
Seriously? You think any company will add screwdrivers to the buy of coffee maker? And you want the company give everyone a new system? That’s called bankruptcy. ? smh
AKA CABUL cabu -
I have the same question as others. Where is they a filter for K-40 ?
keithpawpaw - 답글
Where can I buy the bottom water filter housing? My rubber seal tore
Rodney Baier - 답글
K40 is the best easiest Keurig system takes apart easily clean all part, containers, whatever you see collection of scale or coffee buildup. The filter /screen will never falter or break if you clean this machine once a year as above. The basics every three months or so is to fill the water housing with straight white vinegar and run continuously till empty. Keep filling with clean water to empty till the vinegar smell/ taste is gone. My machine has run perfectly 7 years I bought in 2013. Today is 11/5/2021. I forgot to mention , I haven’t seen my steel screen ripped or torn nor any other plastic /rubber broken so I am sure they have to have these parts somewhere as they would be very cheap to buy.
AKA CABUL cabu - 답글
I need the tube that's in the tank. (White)
Denny Fisher - 답글
댓글 쓰기
조회 통계:
24 시간 전: 4
7일 전: 36
30일 전: 140
전체 시간: 34,461
