주요 콘텐츠로 건너뛰기
이 안내서에는 최근 변경 사항이 더 있습니다. 최신 비검증 버전으로 전환하십시오.
Keurig K40 Bottom Water Filter Replacement
필요한 것
  1. Keurig K40 Bottom Water Filter Replacement, Bottom Water Filter: 1 단계, 이미지 1/2 Keurig K40 Bottom Water Filter Replacement, Bottom Water Filter: 1 단계, 이미지 2/2
    • Flip the device on its side so that the metal faces you.
    • Begin by unscrewing the five 1.5mm bottom screws with a #0 phillips head screwdriver.
  2. Keurig K40 Bottom Water Filter Replacement: 2 단계, 이미지 1/2 Keurig K40 Bottom Water Filter Replacement: 2 단계, 이미지 2/2
    • Once the base is unscrewed, remove the base from the plastic wedges used to hold it in place.
    • The wires do not need to be cut as this repair will not harm or use them.
  3. Keurig K40 Bottom Water Filter Replacement: 3 단계, 이미지 1/2 Keurig K40 Bottom Water Filter Replacement: 3 단계, 이미지 2/2
    • Using a size 0 Philips head screwdriver, remove two 1.2mm screws that hold the filter in place.
    • Pull the pump back to remove it from the slot it was in.
  4. Keurig K40 Bottom Water Filter Replacement: 4 단계, 이미지 1/1
    • Grip where the filter and the flow line connect and pull apart until they are separated.
    • Clean or obtain a new filter and put back together. This is done by repeating the steps in reverse, putting the device back together.
결론
다른 11명이 해당 안내서를 완성하였습니다.
jonathan
회원 가입일: 02/08/16
711 평판
안내서 2개 작성하였습니다
USF Tampa, Team 6-1, Eyestone Spring 2016 USF Tampa, Team 6-1, Eyestone Spring 2016 회원
USFT-EYESTONE-S16S6G1
3 회원들
안내서 5개 작성하였습니다
댓글 12개
Where do you obtain a new filter?
Anthony Montoya - 답글
I have the same question as Anthony. Every Keurig filter I see is the charcoal filter that takes 2 seconds to change
Matt Baum - 답글
[|i have the same question as well.. I don’t see anywhere selling a new filter…]
eddie mayfield - 답글
I need the filter, where do I buy a new Filter?
Gladys Karina Andino - 답글
The answer seems to be: “You don’t.”
Van Davis - 답글
댓글 쓰기
조회 통계:
24 시간 전: 5
7일 전: 25
30일 전: 139
전체 시간: 34,381
