주요 콘텐츠로 건너뛰기
Keurig K40 Open/Close Sensor Replacement
필요한 것
  1. Keurig K40 Open/Close Sensor Replacement, Top Water Pump: 1 단계, 이미지 1/1
    • Begin by removing the top cover from the device.
    • Remove the cover by gently rocking it back and forth with an emphasis on lowering the left side underneath an internal peg.
  2. Keurig K40 Open/Close Sensor Replacement: 2 단계, 이미지 1/1
    • Unscrew both 1.5mm screws located on the water pump.
  3. Keurig K40 Open/Close Sensor Replacement: 3 단계, 이미지 1/2 Keurig K40 Open/Close Sensor Replacement: 3 단계, 이미지 2/2
    • Keeping one hand firmly placed on the device, tug upwards on the water pump until it is separated from the device.
    • The water pump and pipe should now be loose and easy to move as shown.
  4. Keurig K40 Open/Close Sensor Replacement: 4 단계, 이미지 1/2 Keurig K40 Open/Close Sensor Replacement: 4 단계, 이미지 2/2
    • Pull on the point where the pipe meets the water pump.
    • The pipe will come loose and the water filter will be free and ready to be replaced.
  5. Keurig K40 Open/Close Sensor Replacement, Open/Closed Sensor: 5 단계, 이미지 1/2 Keurig K40 Open/Close Sensor Replacement, Open/Closed Sensor: 5 단계, 이미지 2/2
    • Using a #2 Philips head screwdriver remove the 1.2mm screw holding the sensor in place.
    • Locate where the connections are soldered to the sensor
  6. Keurig K40 Open/Close Sensor Replacement: 6 단계, 이미지 1/1
    • Melt the solder that is connected to the sensor.
    • Be careful to avoid any rubber and try to only contact the metal making the connection.
  7. Keurig K40 Open/Close Sensor Replacement: 7 단계, 이미지 1/1
    • Put the replacement sensor back on the post that holds it and begin to solder the two metal connections back to the sensor.
    • Be careful not to touch the end of the soldering iron.
결론
다른 한 분이 해당 안내서를 완성하였습니다.
jonathan
회원 가입일: 02/08/16
738 평판
안내서 2개 작성하였습니다
USF Tampa, Team 6-1, Eyestone Spring 2016 USF Tampa, Team 6-1, Eyestone Spring 2016 회원
USFT-EYESTONE-S16S6G1
3 회원들
안내서 5개 작성하였습니다
댓글 한 개
Where can I get the open/closed sensor? I called Keurig and they told me they don’t handle them.
John Fictum - 답글
댓글 쓰기
조회 통계:
24 시간 전: 1
7일 전: 5
30일 전: 24
전체 시간: 3,745
