소개
In this guide the user will open the top unit of the Keurig and replace the sensor that tells the device if the head unit is open or closed.
필요한 것
Using a #2 Philips head screwdriver remove the 1.2mm screw holding the sensor in place.
Locate where the connections are soldered to the sensor
다른 한 분이 해당 안내서를 완성하였습니다.
댓글 한 개
Where can I get the open/closed sensor? I called Keurig and they told me they don’t handle them.
