주요 콘텐츠로 건너뛰기
Keurig K40 Spring Replacement
필요한 것
  1. Keurig K40 Spring  Replacement, Spring: 1 단계, 이미지 1/2 Keurig K40 Spring  Replacement, Spring: 1 단계, 이미지 2/2
    • Using a Phillips #2 screwdriver unscrew two 2mm screws.
    • Once the screws are out, lift up and squeeze the k-cup assembly housing to take it out.
  2. Keurig K40 Spring  Replacement: 2 단계, 이미지 1/1
    • Use the handle to open the lid then squeeze and move the lid around to take it off.
  3. Keurig K40 Spring  Replacement: 3 단계, 이미지 1/3 Keurig K40 Spring  Replacement: 3 단계, 이미지 2/3 Keurig K40 Spring  Replacement: 3 단계, 이미지 3/3
    • Using the Phillips #0 screwdriver unscrew two 2mm screws on the water pump.
    • Once unscrewed lift the water pump up and pull and twist it off.
  4. Keurig K40 Spring  Replacement: 4 단계, 이미지 1/2 Keurig K40 Spring  Replacement: 4 단계, 이미지 2/2
    • Using the tweezer and the plastic opening tool grab the front of the spring to take it off.
결론
다른 한 분이 해당 안내서를 완성하였습니다.
Michelle Sanchez
회원 가입일: 02/08/16
165 평판
안내서 1개 작성함
USF Tampa, Team 6-1, Eyestone Spring 2016 USF Tampa, Team 6-1, Eyestone Spring 2016 회원
USFT-EYESTONE-S16S6G1
3 회원들
안내서 5개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 4
30일 전: 12
전체 시간: 4,498
