주요 콘텐츠로 건너뛰기
Keurig K40 Top Water Pump Replacement
필요한 것
  1. Keurig K40 Top Water Pump Replacement, Top Water Pump: 1 단계, 이미지 1/1
    • Begin by removing the top cover from the device.
    • Remove the cover by gently rocking it back and forth with an emphasis on lowering the left side underneath an internal peg.
  2. Keurig K40 Top Water Pump Replacement: 2 단계, 이미지 1/1
    • Unscrew both 1.5mm screws located on the water pump.
  3. Keurig K40 Top Water Pump Replacement: 3 단계, 이미지 1/2 Keurig K40 Top Water Pump Replacement: 3 단계, 이미지 2/2
    • Keeping one hand firmly placed on the device, tug upwards on the water pump until it is separated from the device.
    • The water pump and pipe should now be loose and easy to move as shown.
  4. Keurig K40 Top Water Pump Replacement: 4 단계, 이미지 1/2 Keurig K40 Top Water Pump Replacement: 4 단계, 이미지 2/2
    • Pull on the point where the pipe meets the water pump.
    • The pipe will come loose and the water filter will be free and ready to be replaced.
결론
다른 5명이 해당 안내서를 완성하였습니다.
Andrew Bornemann
회원 가입일: 02/08/16
476 평판
안내서 2개 작성하였습니다
USF Tampa, Team 6-1, Eyestone Spring 2016 USF Tampa, Team 6-1, Eyestone Spring 2016 회원
USFT-EYESTONE-S16S6G1
3 회원들
안내서 5개 작성하였습니다
댓글 4개
I NEED ONE OF THESE! Where can I find one????
G Steve - 답글
This is a check valve, not the water pump.
Rick Koen - 답글
Please rename this article. The item is not a water pump.
tvyse46 - 답글
I viewed this to replace the pump. But after the checkvalve was replaced through these instructions my K40 works like new. Thank you.
Glenn Stanley - 답글
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 3
30일 전: 44
전체 시간: 9,389
