주요 콘텐츠로 건너뛰기
Keurig K55 Water Filter Replacement
필요한 것
  1. Keurig K55 Water Filter Replacement, Charcoal water filter: 1 단계, 이미지 1/1
    • Soak the new charcoal filter in water for 5 minutes.
  2. Keurig K55 Water Filter Replacement: 2 단계, 이미지 1/3 Keurig K55 Water Filter Replacement: 2 단계, 이미지 2/3 Keurig K55 Water Filter Replacement: 2 단계, 이미지 3/3
    • Remove the water reservoir from the Keurig machine by gently lifting up on the reservoir and pulling it away.
  3. Keurig K55 Water Filter Replacement: 3 단계, 이미지 1/1
    • Remove the lid from the water reservoir and empty any remaining water from the tank.
  4. Keurig K55 Water Filter Replacement: 4 단계, 이미지 1/2 Keurig K55 Water Filter Replacement: 4 단계, 이미지 2/2
    • Remove water filter holder from within the water reservoir by pulling up on the holder and lifting it out.
  5. Keurig K55 Water Filter Replacement: 5 단계, 이미지 1/2 Keurig K55 Water Filter Replacement: 5 단계, 이미지 2/2
    • To remove the old filter, pinch both sides of the filter holder at the base and pull it apart. Remove the old filter by lifting it out of the filter holder.
    • Dispose of old water filter cartridge.
  6. Keurig K55 Water Filter Replacement: 6 단계, 이미지 1/1
    • Take the soaked water filter and rinse it under running water for 60 seconds.
  7. Keurig K55 Water Filter Replacement: 7 단계, 이미지 1/2 Keurig K55 Water Filter Replacement: 7 단계, 이미지 2/2
    • Place new water filter cartridge into the upper filter holder.
    • Snap the bottom of the filter holder back on by aligning the tabs with the spaces
결론
다른 한 분이 해당 안내서를 완성하였습니다.
Maria Kostourkova
회원 가입일: 06/20/18
160 평판
안내서 1개 작성함
Washington State, Team S1-G6, Hope Summer 2018 Washington State, Team S1-G6, Hope Summer 2018 회원
WSU-HOPE-SU18S1G6
4 회원들
안내서 1개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 1
7일 전: 9
30일 전: 27
전체 시간: 1,108
