주요 콘텐츠로 건너뛰기
Keurig K70 Top Needle Replacement
필요한 것
  1. Keurig K70 Top  Needle Replacement, Handle: 1 단계, 이미지 1/2 Keurig K70 Top  Needle Replacement, Handle: 1 단계, 이미지 2/2
    • Locate the handle on top of the unit
    • Locate the two Torx head screws on the underside of the handle. Remove them with a T15 screwdriver
  2. Keurig K70 Top  Needle Replacement: 2 단계, 이미지 1/3 Keurig K70 Top  Needle Replacement: 2 단계, 이미지 2/3 Keurig K70 Top  Needle Replacement: 2 단계, 이미지 3/3
    • Bend the handle outward to remove
  3. Keurig K70 Top  Needle Replacement, Top  Needle: 3 단계, 이미지 1/1
    • While looking upwards from underneath the Keurig, remove the two 8mm Phillips #2 screws from underneath the black plastic "shroud".
    • Remove the black plastic "shroud" by pushing inwards and then pulling upwards to disengage the plastic hooks that are not visible.
  4. Keurig K70 Top  Needle Replacement: 4 단계, 이미지 1/3 Keurig K70 Top  Needle Replacement: 4 단계, 이미지 2/3 Keurig K70 Top  Needle Replacement: 4 단계, 이미지 3/3
    • Remove the two 8 mm screws with a PH #1 screwdrver
    • Pull on the plastic tube to remove it
    • This will require a generous amount of force
  5. Keurig K70 Top  Needle Replacement: 5 단계, 이미지 1/1
    • Remove the two 8mm screws with a PH #2 screwdriver.
  6. Keurig K70 Top  Needle Replacement: 6 단계, 이미지 1/1
    • Pull out on the top component perpendicular to the top face as shown. It will pop out without too much effort.
    • The needle is now exposed on the bottom of the part being handled in this photo. Be careful where you grab this component, we recommend doing as we have done here. Grab the front "lip" of the component (see photo).
  7. Keurig K70 Top  Needle Replacement: 7 단계, 이미지 1/1
    • This is the component that should detach after pulling down.
    • Be careful of the needle!
  8. Keurig K70 Top  Needle Replacement: 8 단계, 이미지 1/1
    • On the bottom of the component is the exposed needle, which is now accessible.
    • If you remove the needle be careful as it may be sharp.
결론
다른 2명이 해당 안내서를 완성하였습니다.
Alec Foster
회원 가입일: 10/06/16
161 평판
안내서 1개 작성함
Cal Poly, Team 20-4, Livingston Fall 2016 Cal Poly, Team 20-4, Livingston Fall 2016 회원
CPSU-LIVINGSTON-F16S20G4
4 회원들
안내서 5개 작성하였습니다
2 댓글
If the needle were sharp this wouldn’t be necessary.
Can a replacement ‘needle’ be purchased somewhere? This must be almost universal and should be easily obtainable from Keurig.
krrjr49 - 답글
Did you find a place to purchase a replacement top needle? All I can find is the bottom exit needle assembly.
Liz Mark - 답글
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 6
30일 전: 40
전체 시간: 3,599
