주요 콘텐츠로 건너뛰기
Keurig K75 Water Pump Replacement
필요한 것
  1. Keurig K75 Water Pump Replacement, Water Pump: 1 단계, 이미지 1/1
    • Here she is. Now lets take her apart!
    • Be sure to unplug the unit or risk a dangerous electric shock.
    • Remove the water reservoir and the cup rest; set them aside.
  2. Keurig K75 Water Pump Replacement: 2 단계, 이미지 1/1
    • Start by removing the bottom cover.
    • These 5 screws hold it on, remove them.
    • This rivet connects the ground rivets to the cover, it will need to be drilled out to fully remove the cover.
    • Do not remove the feet as it is not necessary.
  3. Keurig K75 Water Pump Replacement: 3 단계, 이미지 1/2 Keurig K75 Water Pump Replacement: 3 단계, 이미지 2/2
    • View without cover.
    • Here is the water pump.
    • Water tank
    • Inlet, remove the two screws as it is attached to the pump
    • Remove these screws to free the pump. once free *carefully* cut the cable ties on the two hoses so it can be removed
    • Once all the lines are free you will need to un-solder the two wires attached to the pump so that it can be fully removed.
  4. Keurig K75 Water Pump Replacement: 4 단계, 이미지 1/2 Keurig K75 Water Pump Replacement: 4 단계, 이미지 2/2
    • And there you have it. If you have a new one you can now install it.
    • Don't forget to replace those zip ties that you cut off.
    • If you don't have a new one you can try to fix this one by removing these four screws and removing any blockage.
    • Now Keurig doesn't stock spare parts, so unless you can get your hands on another broken machine you will need to fix the existing motor or source a new one. Radio Shack stocks small motors like this, they won't be exact but with a little modification you should be able to get it working.
결론
다른 9명이 해당 안내서를 완성하였습니다.
Dans iPod Repair
회원 가입일: 07/19/10
278 평판
안내서 1개 작성함
댓글 10개
how do you know if its your water pump not working? when I turn on my keurig, and the not ready sign is on, the water starts running out of the top like it has a K cup in it but it does not. It just needs the water to fill inside to be in the ready state. A couple days ago I was able to brew a cup and now it wont work.. HELP!
ashley - 답글
Your going to need to be a little more specific. Explain it in detail and I'll have a better idea of what's going on.
Dans iPod Repair - 답글
Hi Dan.. Happy New Year.
Would you know if this is the only motor in the unit?
I've removed it but would like to test it before I replace it to make sure it is defective.
Any suggestions on how to best test?
mark -
My Keurig does work, but it makes a ton of noise like vibrating until the brewing begins. Could this the same culprit?
Raymond Cardenas - 답글
Do any of you know why a Keurig B77 would shut off when refilling the chamber after brewing? This happens after each cycle. The cup brews, starts filling the chamber then shuts off. When you turn it back on it continues to fill until it reaches the limit. Any help will be appreciated.
momto2 - 답글
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 9
30일 전: 35
전체 시간: 109,846
