주요 콘텐츠로 건너뛰기
Keyboard Logitech K800 Battery replacement
필요한 것
  1. Keyboard Logitech K800 Battery replacement, Open the battery location: 1 단계, 이미지 3개 중 1개 Keyboard Logitech K800 Battery replacement, Open the battery location: 1 단계, 이미지 3개 중 2개 Keyboard Logitech K800 Battery replacement, Open the battery location: 1 단계, 이미지 3개 중 3개
    • Once the battery location open, replace the original battery with new rechargeable batteries.
결론
To re-assemble your keyboard, reverse instructions.
다음 번역가들에게 특별히 감사 드립니다:
fr en
100%
Maxime Veber님은 저희가 세상을 수리하는데 동참하신 분입니다! 기여하시겠습니까?
번역 시작하기 ›
작성자
1다른 기여자 명과 함께
Maxime Veber
회원 가입일: 12/21/20
109 평판
안내서 1개를 작성함
댓글 8개
If the keyboard doesn’t work with the new batteries, doesn’t charge the batteries, or doesn’t communicate with the unifying receiver, a mainboard replacement may be necessary. The replacement circuit board can be purchased via eBay. Search eBay for “210-000797” which is the code for the PCB.
Simon - 답글
Actually, if the battery change doesn’t work, it’s more probable that the issue is a cable disconnected around the location of the batteries. A little piece of tape on the cable will fix it!
Maxime Veber - 답글
They changed the design. The batteries are no longer accessible through the slot. They want you to trash it and get another one. Can you guys do another teardown for the new eco-destructive design?
Sam Anderson - 답글
yeah I have design purchased from bestbuy around 2015 or 16 with hidden battery and 50 steps to replace.
This tutorial on how to replace the old k800 version batteries easily accessible under the simple cover plate is sofa king useless :)
ok maybe people actually need tutorials on how to replace batteries in remotes or flashlights, my bad.
jimi -
If you’re looking for a solution in the exact same model, you can still remove the entire backside of the keyboard and replace batteries :) . It’s a bit more complicated, but I did it and it’s fine. You can find videos online about how to do it.
Maxime Veber - 답글
댓글 쓰기
조회 통계:
지난 24시간: 2
지난 7일: 20
지난 30일: 78
전체 시간: 6,249
