주요 콘텐츠로 건너뛰기
Keyboard replacement on a why! W253EU
필요한 것
  1. Keyboard replacement on a why! W253EU, Battery from why! Remove W253EU: 1 단계, 이미지 1/3 Keyboard replacement on a why! W253EU, Battery from why! Remove W253EU: 1 단계, 이미지 2/3 Keyboard replacement on a why! W253EU, Battery from why! Remove W253EU: 1 단계, 이미지 3/3
    • Turn off the computer.
    • Before each operation it is important to start with the removal of the accumulator.
    • Take the slide unlocked into position, remove the battery.
  2. Keyboard replacement on a why! W253EU, Keyboard: 2 단계, 이미지 1/3 Keyboard replacement on a why! W253EU, Keyboard: 2 단계, 이미지 2/3 Keyboard replacement on a why! W253EU, Keyboard: 2 단계, 이미지 3/3
    • Use a Phillips # 1 screwdriver to remove the two screws located in the slot of the accumulator.
    • Insert a standard screwdriver into the slot in the cover above the keyboard.
    • Lift the cover with the usual care.
  3. Keyboard replacement on a why! W253EU: 3 단계, 이미지 1/3 Keyboard replacement on a why! W253EU: 3 단계, 이미지 2/3 Keyboard replacement on a why! W253EU: 3 단계, 이미지 3/3
    • Use a Phillips # 1 screwdriver to remove the four screws securing the keyboard in the upper part.
  4. Keyboard replacement on a why! W253EU: 4 단계, 이미지 1/2 Keyboard replacement on a why! W253EU: 4 단계, 이미지 2/2
    • Turn the keyboard towards the screen.
    • Carefully remove the connection cable in the direction of the plug axis.
결론
For reassembly, follow the instructions in reverse order.
다음 번역가들에게 특별히 감사 드립니다:
de en
100%
이 번역자 분들은 저희가 세상을 수리하는데 동참해 주시는 분입니다! 기여하시겠습니까?
번역 시작하기 ›
Felice Suglia
회원 가입일: 06/15/13
30,884 평판
안내서 263개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 2
30일 전: 2
전체 시간: 450
