주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Keychron K10 Max Wireless Keycap Replacement
필요한 것
  1. Keychron K10 Max Wireless Keycap Replacement, Keycap: 1 단계, 이미지 3개 중 1개 Keychron K10 Max Wireless Keycap Replacement, Keycap: 1 단계, 이미지 3개 중 2개 Keychron K10 Max Wireless Keycap Replacement, Keycap: 1 단계, 이미지 3개 중 3개
    • Lay the keyboard face down on the workspace.
    • Use a 2.5 mm hex screwdriver to remove the eight 4.5 mm screws from the back case.
    • Carefully separate the front frame from the keyboard and set it aside.
    • There is a clear shield that sits right above the arrow keys. This shield is to diffuse the LEDs from the keyboard, and it can fall out easily. Just remember to put it back if it does when reassembly.
  2. Keychron K10 Max Wireless Keycap Replacement: 2 단계, 이미지 2개 중 1개 Keychron K10 Max Wireless Keycap Replacement: 2 단계, 이미지 2개 중 2개
    • Slide the keycap puller over the keycap until it grips underneath.
    • Pull straight upward to remove the keycap.
    • Sometimes the mechanical switch itself comes with the keycap. Just remove the switch from the button and reinstall the switch.
결론
To reassemble your device, follow these instructions in reverse order. Take your e-waste to an R2 or e-Stewards certified recycler.
작성자
1다른 기여자 명과 함께
Richard Witkowski
회원 가입일: 03/23/26
595 평판
안내서 5개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 22
지난 30일: 26
전체 시간: 31
