주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Kicker CXA300.1 Capacitor Replacement
필요한 것
  1. Kicker CXA300.1 Capacitor Replacement, Capacitor: 1 단계, 이미지 1개 중 1개
    • Remove the five T10 Torx screws from the housing.
  2. Kicker CXA300.1 Capacitor Replacement: 2 단계, 이미지 1개 중 1개
    • Remove the two T10 Torx screws from the faceplate.
  3. Kicker CXA300.1 Capacitor Replacement: 3 단계, 이미지 2개 중 1개 Kicker CXA300.1 Capacitor Replacement: 3 단계, 이미지 2개 중 2개
    • Remove the six T10 Torx screws from the bottom.
    • Pull off the bottom.
  4. Kicker CXA300.1 Capacitor Replacement: 4 단계, 이미지 1개 중 1개
    • Desolder the capacitor and remove.
    • Refer to iFixit’s soldering guide to reattach capacitor.
결론
다른 한 분이 해당 안내서를 완성하였습니다.
작성자
3다른 기여자 명과 함께
Tim Keptya
회원 가입일: 04/12/18
561 평판
안내서 4개를 작성함
UW Tacoma, Team S1-G3, Liner Spring 2018 UW Tacoma, Team S1-G3, Liner Spring 2018 회원
UWT-LINER-S18S1G3
3 회원들
안내서 5개를 작성함
2가이드 댓글
Are you out of your mind or was this a late April Fools joke?!? That is NOT how you replace a capacitor, all you did was tear one off the board and take pictures of the carnage.
To replace a through-hole or snap-in capacitor you need to remove the board from the heat sink and (de)solder on the under side. In addition, proper selection of your replacement parts is crucial to the long-term viability of your repair.
If you are replacing a leaky/ruptured capacitor (or in this case, one that’s been torn off the board by a caveman) it’s critical to thoroughly clean any areas of the board and all components that were exposed to the electrolyte. The electrolyte in electrolytic capacitors is corrosive and will destroy the circuit board if it is not removed.
Tim, I encourage a response. Lets get some dialogue going.
Matt - 답글 공유
Exactly.👍👍👍👍👍
Amindio - 답글 공유
댓글 쓰기
조회 통계:
지난 24시간: 3
지난 7일: 11
지난 30일: 68
전체 시간: 1,480
