주요 콘텐츠로 건너뛰기
Kid Galaxy Morphibians Explorer Axle Replacement
필요한 것
  1. Kid Galaxy Morphibians Explorer Axle Replacement, Axle: 1 단계, 이미지 1/1
    • Remove both 8.0 mm Phillips #1 screws, one for each wheel.
  2. Kid Galaxy Morphibians Explorer Axle Replacement: 2 단계, 이미지 1/1
    • Remove the wheels by pulling them away from the RC car.
  3. Kid Galaxy Morphibians Explorer Axle Replacement: 3 단계, 이미지 1/1
    • Make note of where each driving gear cover is placed. They only go in one way.
    • Remove the eight 8.0mm Phillips #00 screws, two screws for each wheel.
  4. Kid Galaxy Morphibians Explorer Axle Replacement: 4 단계, 이미지 1/1
    • Pry open the two gear covers on both sides.
  5. Kid Galaxy Morphibians Explorer Axle Replacement: 5 단계, 이미지 1/1
    • Pull the driving gears off the axles by sliding them off the axles and exposing both axles.
  6. Kid Galaxy Morphibians Explorer Axle Replacement: 6 단계, 이미지 1/1
    • Slide both axles from the internal axles guides within the car.
    • Reverse the steps to replace the axles.
결론
Rusbell Gonzalez
회원 가입일: 09/17/14
219 평판
안내서 5개 작성하였습니다
USF Tampa, Team 1-2, Hickman Fall 2014 USF Tampa, Team 1-2, Hickman Fall 2014 회원
USFT-HICKMAN-F14S1G2
3 회원들
안내서 7개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 1
30일 전: 4
전체 시간: 292
