주요 콘텐츠로 건너뛰기
Kid Galaxy Morphibians Explorer Battery Replacement
필요한 것
  1. Kid Galaxy Morphibians Explorer Battery Replacement, Battery: 1 단계, 이미지 1/1
    • First, completely loosen the 9.6 mm Phillips #2 screw on top. There is a plastic washer that holds the screw to the top cover, so it will not need to be taken out.
  2. Kid Galaxy Morphibians Explorer Battery Replacement: 2 단계, 이미지 1/1
    • After the screw has been loosened, lift the cover off.
  3. Kid Galaxy Morphibians Explorer Battery Replacement: 3 단계, 이미지 1/1
    • Completely loosen the 9.6 mm Phillips #2 screw from the battery cover. Once again, there is a plastic washer to hold the screw to the cover.
  4. Kid Galaxy Morphibians Explorer Battery Replacement: 4 단계, 이미지 1/1
    • Lift the battery cover to gain access to the batteries.
    • Replace the 3 AA batteries and reverse the steps to put everything back together.
결론
Rusbell Gonzalez
회원 가입일: 09/17/14
219 평판
안내서 5개 작성하였습니다
USF Tampa, Team 1-2, Hickman Fall 2014 USF Tampa, Team 1-2, Hickman Fall 2014 회원
USFT-HICKMAN-F14S1G2
3 회원들
안내서 7개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 0
30일 전: 11
전체 시간: 2,561
