소개
If your Kid Galaxy Morphibians Explorer controller (Model number: QEA-E097-49R) is not working, it probably just requires a quick battery replacement. This guide will inform users on how to replace their controller battery. The only required tool is a Phillips #2 screwdriver.
Be aware of possible battery corrosion. If a battery has corroded, or leaked out any battery acid, carefully remove the battery and wipe all remaining acid off of the toy before replacing the battery.
필요한 것
다른 한 분이 해당 안내서를 완성하였습니다.
