소개
Before starting your repair, remove the battery to take away all risk of electrical shock. While taking apart the Kid Galaxy Morphibian Explorer there are many small moving parts that are easily broken, so be cautious when removing components. There are many wires once you have removed the outer cover of the Kid Galaxy Explorer, so be aware of which wires are being removed and where they will be put back.
필요한 것
First, completely loosen the 9.6 mm Phillips #2 screw on top. There is a plastic washer that holds the screw to the top cover, so it will not need to be taken out.
On the top of the inside cover you will see the back side of the on/off switch. Remove the two 7.2 mm Philips #00 head screws holding the switch in place.
댓글 한 개
In the last step, Step 8 second bullet. Could add a image of actually showing how its done.
