주요 콘텐츠로 건너뛰기
Kid Galaxy Morphibians Explorer Outer Cover Replacement
필요한 것
  1. Kid Galaxy Morphibians Explorer Outer Cover  Replacement, Remove the Top Cover: 1 단계, 이미지 1개 중 1개
    • First, completely loosen the 9.6 mm Phillips #2 screw on top. There is a plastic washer that holds the screw to the top cover, so it will not need to be taken out.
  2. Kid Galaxy Morphibians Explorer Outer Cover  Replacement: 2 단계, 이미지 1개 중 1개
    • After the screw has been loosened, lift the cover off.
  3. Kid Galaxy Morphibians Explorer Outer Cover  Replacement: 3 단계, 이미지 1개 중 1개
    • Completely loosen the 9.6 mm Phillips #2 screw from the battery cover. Once again, there is a plastic washer to hold the screw to the cover.
  4. Kid Galaxy Morphibians Explorer Outer Cover  Replacement: 4 단계, 이미지 1개 중 1개
    • After the screw is loosened, lift the battery cover off the top cover to gain access to the batteries.
    • Turn the RC car over to reach the six screws on the bottom.
  5. Kid Galaxy Morphibians Explorer Outer Cover  Replacement: 5 단계, 이미지 1개 중 1개
    • Remove the six 11.6 mm Phillips #2 screws on the bottom cover.
    • (Wheels are removed in this picture to clearly show screw location. They do not need to be removed for this step)
  6. Kid Galaxy Morphibians Explorer Outer Cover  Replacement: 6 단계, 이미지 1개 중 1개
    • Lift the top Cover off the car.
결론
작성자
5다른 기여자 명과 함께
Eric Studstrup
회원 가입일: 09/22/14
4 평판
안내서 2개를 작성함
USF Tampa, Team 1-2, Hickman Fall 2014 USF Tampa, Team 1-2, Hickman Fall 2014 회원
USFT-HICKMAN-F14S1G2
3 회원들
안내서 7개를 작성함
댓글 한 개
As i can see in the last image. There are some wires still connected with the outer cover. Could have shown couple more images how to get them off. Everything else looks great.
Dishant Patel - 답글
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 7
지난 30일: 20
전체 시간: 262
