소개
There are a few layers that you have to work through to get to the inside of the Kid Galaxy Explorer. There are screws on the top and bottom holding the Kid Galaxy Explorer together so if it is not coming apart do not pry it open; check for more screws.
필요한 것
First, completely loosen the 9.6 mm Phillips #2 screw on top. There is a plastic washer that holds the screw to the top cover, so it will not need to be taken out.
댓글 한 개
As i can see in the last image. There are some wires still connected with the outer cover. Could have shown couple more images how to get them off. Everything else looks great.
