주요 콘텐츠로 건너뛰기
Kid Motorz Xtreme Quad 12V Vehicle Battery Repair
필요한 것
  1. Kid Motorz Xtreme Quad 12V Vehicle Battery Repair, Kid Motorz Xtreme Quad 12V Vehicle Battery Repair: 1 단계, 이미지 1/1
    • Remove the screw at the back of the seat.
    • Remove the seat from the device.
  2. Kid Motorz Xtreme Quad 12V Vehicle Battery Repair: 2 단계, 이미지 1/1
    • Remove the two screws along the bracket.
    • Remove the bracket.
  3. Kid Motorz Xtreme Quad 12V Vehicle Battery Repair: 3 단계, 이미지 1/1
    • Disconnect battery by gently pushing the tabs inwards and carefully unplugging it.
  4. Kid Motorz Xtreme Quad 12V Vehicle Battery Repair: 4 단계, 이미지 1/2 Kid Motorz Xtreme Quad 12V Vehicle Battery Repair: 4 단계, 이미지 2/2
    • Remove the battery terminals and the battery.
  5. Kid Motorz Xtreme Quad 12V Vehicle Battery Repair: 5 단계, 이미지 1/1
    • Put safety gloves on before beginning to solder.
    • Take your solder and place it carefully on the terminal points of the battery (negative and positive).
  6. Kid Motorz Xtreme Quad 12V Vehicle Battery Repair: 6 단계, 이미지 1/1
    • Apply heat to the solder.
  7. Kid Motorz Xtreme Quad 12V Vehicle Battery Repair: 7 단계, 이미지 1/2 Kid Motorz Xtreme Quad 12V Vehicle Battery Repair: 7 단계, 이미지 2/2
    • Position the wire onto the end piece and apply heat to the solder.
  8. Kid Motorz Xtreme Quad 12V Vehicle Battery Repair: 8 단계, 이미지 1/2 Kid Motorz Xtreme Quad 12V Vehicle Battery Repair: 8 단계, 이미지 2/2
    • Put the battery back into its compartment.
    • Plug the battery back in.
  9. Kid Motorz Xtreme Quad 12V Vehicle Battery Repair: 9 단계, 이미지 1/1
    • Place the bracket back into its slot.
    • Screw the bracket screws back into place.
  10. Kid Motorz Xtreme Quad 12V Vehicle Battery Repair: 10 단계, 이미지 1/1
    • Place the seat back onto the device.
    • Screw the seat screw back into place.
  11. Kid Motorz Xtreme Quad 12V Vehicle Battery Repair: 11 단계, 이미지 1/1
    • Congratulations you are now ready to ride again!
결론
The goal of this guide is to repair a battery terminal through solder and after completing the guide you should be able to apply what you learned to other projects and similar electronics
다른 한 분이 해당 안내서를 완성하였습니다.
Yanal
회원 가입일: 02/20/23
243 평판
안내서 1개 작성함
University of Memphis, Team Z-99, Cameron Spring 2023 University of Memphis, Team Z-99, Cameron Spring 2023 회원
UM-CAMERON-S23SZG99
1 회원
안내서 2개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 1
30일 전: 15
전체 시간: 168
