소개
Replace the battery in a kid's digital watch.
필요한 것
Remove the four (4) screws on the backside of the watch with the small Philips head screwdriver.
Remove using tweezers the circuit protector plate that is uncovered once the backplate is removed.
With the tiny Philips head screwdriver, unscrew and remove the screw closest to the blue component.
Now remove the screw on the other side of the battery near the yellow circuit component.
Using tweezers carefully remove the battery protector plate.
다른 한 분이 해당 안내서를 완성하였습니다.
