주요 콘텐츠로 건너뛰기
KidzLane Walkie-Talkie Press-to-speak button Replacement
필요한 것
  1. KidzLane Walkie-Talkie Press-to-speak button Replacement, Press-to-speak button: 1 단계, 이미지 1개 중 1개
    • Place the Walkie-Talkie on a flat surface-preferably a table or a desk.
    • Flip the device over to where you see four screws in each corner.
    • Make sure you take out the batteries before proceeding.
  2. KidzLane Walkie-Talkie Press-to-speak button Replacement: 2 단계, 이미지 2개 중 1개 KidzLane Walkie-Talkie Press-to-speak button Replacement: 2 단계, 이미지 2개 중 2개
    • Using your Phillips head screwdriver, unscrew all four 4mm screws from each corner.
  3. KidzLane Walkie-Talkie Press-to-speak button Replacement: 3 단계, 이미지 1개 중 1개
    • Once you have unscrewed all four corners, open the device so it will be in two parts.
    • As you're opening the inside of the Walkie-Talkie, don't break off any wires within the device.
    • Taking the Phillips head screwdriver again, unscrew the three screws on the circuit board (green plate).
    • Separate these screws from the other four since they are different sizes.
  4. KidzLane Walkie-Talkie Press-to-speak button Replacement: 4 단계, 이미지 2개 중 1개 KidzLane Walkie-Talkie Press-to-speak button Replacement: 4 단계, 이미지 2개 중 2개
    • Take the circuit board out of the plastic casing.
    • Use the soldering device to iron the silver box (press-to-speak button), and then remove it from the circuit board.
결승점
다른 2명이 해당 안내서를 완성하였습니다.
작성자
7다른 기여자 명과 함께
Amin
회원 가입일: 02/13/16
642 평판
안내서 5개를 작성함
IUPUI, Team 1-1, Wilson Spring 2016 IUPUI, Team 1-1, Wilson Spring 2016 회원
IUPUI-WILSON-S16S1G1
4 회원들
안내서 5개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 0
지난 30일: 9
전체 시간: 1,006
